Parts Guy: "Lowering a truck will not cause a vibration....."
Old Mar 17, 2012 | 10:49 AM
  #41
Atomic's Avatar
I have a gauge for that
Orileys actually sell them, and rough country makes some really long ones.
Old Mar 17, 2012 | 11:31 AM
  #42
53RUSSELL's Avatar
Originally Posted by BlackGMC
I allready had a longer center pin. The shims i allready had came with one.
On the kit i got the stud part of the center pin is not long enough to go through the shim and through the spring perches . What kit did you order? Thanks
Old Mar 17, 2012 | 01:36 PM
  #43
BlackGMC's Avatar
Resident Retard
I believe your issue is the shim. I believe that shim is supposed to be used with a lift block, which the hole is bigger. I ended up pitting on a rubican express steel shim. The hole is very small and i had to open it up a little. I have some ruff country shims that should be delivered in a week or so, which i will probably return.
Old Mar 17, 2012 | 01:51 PM
  #44
53RUSSELL's Avatar
Any part #s on the shims you got. Send me a pm on how munch you want for them and what * they are
Old Mar 17, 2012 | 02:02 PM
  #45
BlackGMC's Avatar
Resident Retard
Will do later in this evening
Old Mar 18, 2012 | 04:39 PM
  #46
xx_ED_xx's Avatar
Yeah I used some shims where i had to drill the hole out, I went to autozone for the tr6's.
Yeah that pinion angle is atrocious Ferocity. But on my mcguahys drop I think i had to use some 4 degree shims to get it level again. My ridetech setup was dead nuts when installed.
wrb002
Aug 31, 2015 12:00 PM
92SS Wagon
14
Aug 4, 2015 06:42 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
Suburban2500
Jul 14, 2015 02:10 AM
