p0502 when launching under boost
If i want to race someone and i line up to them, ill stall truck up in first till it barely makes boost then leave hard but trans will go into limp mode and pull this p0502 code which is vss. If i just leave hard without boosting it does fine. I dont get it. When it goes into limp mode ofcourse i lose the race cause it shifts into second and thats it. Im gonna change out the sensor first and see what happens.
I just re-read the conditions for setting the DTC, I don't stall up past 2000 rpm, so I guess it's apples & oranges.
If you're stalling over 3000 rpm for over 3 seconds, the DTC may set. Here's the first half of the printout off Mitchell.
Maybe you can use HPT to adjust something. Says "torque between 40-400 ft lbs. Maybe max allowed torque settings need increased? IDK.
bluestang50
Sep 21, 2015 08:36 AM
elir_mn
Sep 19, 2015 11:43 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
