Official A4 to M6 (T-56) Thread!
#881
anyone have an idea what this clutch master is about?
http://www.dormanproducts.com/p-33605-cm640037.aspx
says its for 6 speeds?
#884
are there any aftermarket master cylinders that work better than the factory one?
or are there any stock replacements that are better?
p.s. i already have the t-56 in and have been driving for about a year on it
#885
Sorry, but no. Find a clutch that isn't as taxing on hydraulics.
#886
#887
Look what I found on honda-tech.com, before you guys give me crap I googled "T56 silverado radix" so.. that's how I ended up on a Honda forum LOL
http://www.honda-tech.com/showthread.php?t=2568141
Truck was sold back in 2008
https://ls1tech.com/forums/vehicles-...10k-miles.html
#888
Hey guys quick question.
this thread is an a4 to m6 swap. I need a m5 to m6 swap.
I have an 05 M5 silverado regular cab regency rst.
What year T56 swap do you recommend? a ctsv t56 or newer camaro t56 or stick to an older 98-02 camaro?
Also will my current cross member still work or no I need a different one.
What length driveshaft will I need after the swap?
Lastly anything else I need before i start buying the parts thanks!!
#889
Since I just did this. you will want a camaro ls1 trans. put an 04 auto reluctor wheel on trans and reuse your speed sensor. reuse crossmember. auto matic driveshaft for your truck. I would also use an ls1 metal t/o bearing instead of the m5 plastic one. you can swap the fittings
