Official A4 to M6 (T-56) Thread!
Old Aug 15, 2010 | 03:08 PM
  #821
Quik's Avatar
5 year bitches!
with the weight of our trucks the clutches on the market dont seem to carry the same rating as they do for the cars. the clutch i had prior suppose to be rated to 7-800 but it didnt last long at those levels behind a heavy truck
Old Aug 15, 2010 | 03:17 PM
  #822
regcabls6's Avatar
im makin about 450 wheel know but with the plans of nitrious in the close future i wanna make shure the clutch i pick is gunna hold out. Just cant stand the puck style chatter. Is a solid disk twin agressive as well?
Old Aug 15, 2010 | 09:23 PM
  #823
Quik's Avatar
5 year bitches!
also got to becareful with clutches having to strong of a pressure plate and killing the pedal. i had to put a steel plate on the firewall cause i kept breaking pedals. this eliminates the whole plastic pedal square. i still use stock pedal but use a reinforcement plate on firewall for the master. however the stock master's bore isnt large enough for real clutches. im looking into other options to cure this as i got make this T56 **** work for me.
Old Aug 16, 2010 | 07:45 PM
  #824
regcabls6's Avatar
Do you have to worry about the pedal even if my truck came with manual trans?
Old Aug 16, 2010 | 10:31 PM
  #825
Quik's Avatar
5 year bitches!
yes, the pedal is weak plastic and when you go aftermarket clutch which has a strong pressure plate the plastic flange where the master clicks in is the weakest link. ive bent the pushrod as well cause of a stiff clutch. my pushrod is not 5/16 solid rod
Old Aug 19, 2010 | 10:51 AM
  #826
2001CamaroGuy's Avatar
FYI: for guys with the tranny temp gauge in their cluster, you can still use the gauge if you keep an "automatic based tune" (ie: take a tune from an A4 truck, turn off all the codes, and adjust parameters) and use a factory water temp sensor. The "automatic based tune" is needed in order to keep the sensor pins enabled in the ECU (manual trucks don't have these pins enabled). Splice a coolant temp sensor connector onto the factory tranny temp wires and install the sensor in whatever you want (engine oil/tranny/etc).
I have my sensor installed into the oil block of my engine oil cooler. The reading is dead on (at dead on as the water temp sensor is at reading water temp). I have confirmed the readings are correct by hooking the tranny temp plug onto the engine coolant temp sensor (in the cylinder head) and the temps matched back to back.
Old Aug 22, 2010 | 10:50 AM
  #827
Ketis's Avatar
i have a quick question for t-56 swappers.
i have an auto tune with the dtcs removed and when i shift into neutral on the highway and let off the gas the truck will sometimes stall. anyone have an idea what that would be?
Old Aug 22, 2010 | 02:41 PM
  #828
Try adding more running air and up the idle under speed tables. You need more air so the engine catches itself before it stalls.
Old Aug 22, 2010 | 02:43 PM
  #829
Odd, but by going back to the automatic tune (to use the above posted tranny temp gauge as my oil temp gauge), I now have cruse in 6th gear. My speedo is correct and everything else is working as it should. The only issue I have run into is that unless I push the clutch BEFORE I key on the ignition, the truck doesn't power on "in park" and thus won't start. If I push the clutch BEFORE I key on, it starts.
Old Aug 22, 2010 | 09:18 PM
  #830
TurboGibbs's Avatar
Interesting. I guess I could take an automatic truck I have licensed, change the VIN on mine to it and copy all the files etc. Never really thought about it but it should work. What do you think?
