Official A4 to M6 (T-56) Thread!
#401
i have a ls1 t56. just had it double checked at t56 inc.
im using the truck pilot bearing cuz page 1 says use car or truck bearing. they game me the ls1 car pilot bearing and said thats what i need but it is smaller than the truck pilot bearing and doesnt look like it will fit in my crank
#405
Pull it out and use the second style one. The one pictured it the bushing style I run the ball bearing style. Then again the 99 maybe dirrerant. Any one do a 99 yet that can help him out?
#407
Originally Posted by badinfluencelsx
i have a 99 silverado 4.8 and 4l60e
#408
https://www.performancetrucks.net/fo...d.php?t=331673
This guy did the swap way back and he ran into some similar problems. Do a search under his name and you'll find more info.
The first thing I would do is bolt up your flywheel with the bell housing and then bolt up the starter. See if it will line up with the teeth on the flywheel when the solenoid is engaged. That will tell you if the crank is right on not.
Just trying to eliminate some variables here.
