new trans in, truck wont idle and dies at stops
Old Jan 31, 2012 | 10:25 AM
2doorfury's Avatar
Default new trans in, truck wont idle and dies at stops
truck doesnt want to idle and dies when making stops. when going through gears at idle (pnd321) it bogs down as if it wants to die..i have no clue to why it might be doing this? i dont see how swaping a converter and tranny would effect the engine idle?? any ideas guys? my trucks been comming along great too.
Old Jan 31, 2012 | 10:32 AM
BlackGMC's Avatar
Resident Retard
did you switch to a different converter? if so your idle settings are gonna need some work in the tune... Mainly desired airflow and throttle cracker and throttle follower, perhaps a little tweak to the spark....
Old Jan 31, 2012 | 10:40 AM
2doorfury's Avatar
yes, yank sst 3600. is there anyway of temperarly getting it to run? i wanted to wait for my tune until after the exhaust and gears. i dont daily drive this. i just need it to run good enough to drive to the exhaust shop.
Old Feb 3, 2012 | 04:49 PM
2doorfury's Avatar
bump..anyone have this issue??
Old Feb 4, 2012 | 03:45 PM
Vince B's Avatar
As Corey mention above you need to get a tune done to fix this issue you are having. I have seen this complaint many times when guys install a converter with a smaller diameter and also a high stall. You will also want to remove the code tests for the PO751 and the PO757 in your tune as well. As for driving it to the exhaust shop it is what it is at this point. Use two feet or slip it in neutral!
Old Feb 4, 2012 | 08:49 PM
GREENSIERRA's Avatar
I had this problem aswell when I swapped to my 3200 converter. a tune will cure it.
2 stepping will get you where you have to go tho.
Old Feb 5, 2012 | 11:38 AM
James B.'s Avatar
If it's bogging while going through gears sitting still it's not just tuning. If anything, a higher-stall torque converter should be trying to move LESS torque at idle than a stock converter by far. It sounds more to me like the converter lockup clutch is dragging.
Old Feb 5, 2012 | 01:09 PM
LS1FREEK's Avatar
13 Second Truck Club
I'm with James, sounds like the converter clutch is partially engaging or something...
Old Feb 6, 2012 | 11:32 PM
2doorfury's Avatar
thanks guys, well i guess ill start with the tune and see if it will fix it.
Tig
Sep 30, 2015 07:39 PM
GMCtrk
Jul 17, 2015 06:39 PM
black6spdz
Jul 16, 2015 01:32 AM
rojeho
Jul 12, 2015 06:10 PM
GreyChevy
Jul 7, 2015 08:57 PM
