New rebuilt 80e no reverse and slipping
Old Jun 25, 2010 | 06:46 PM
2005 Silverado's Avatar
SPAM HUNTER
Default New rebuilt 80e no reverse and slipping
First if your going to bash the builder get the **** out.
I Finished up the swap and got the driveshaft today go to shift have drive 3 2 1 but no reverse, i spoke to a sponser (will not mention any names) and he gave me some help and says its something internal, can i get a list of the problems that could cause the 80e no reverse issue?
Next i tried to just get it home from the shop (i had the forward gears) and its only like 2 miles so i start out 1st good, into 2nd, 3rd feels like it slips then it went finally, then i fell lock up (stock 50mph) and when it hits 4th it was like it was slipping in and out so i just let out and got it back to the shop.
Temp on EFI live only got to 160 cruising, the 2500 gm high stall roadrunner converter is all the 2500 and then some...again the sponser thinks that was low fluid but i said screw it, it needs to be checked out anyways and gave up.
Little bit of a rant/ list of issues
Specs are
1998 80e 2wd
Rebuilt with the Premium Overhaul Race Kit Box with Kolene¨ Steels from hughes and used new GM 4th gear steeles as recommended since the kit doesnt have them
Stock hard parts
HD sprag
transgo 2 with medium shift kit
GM highstall rebuilt by roadrunner converter.
Lastly is this something that any trans shop can look at or even i can look at, i am a mechanic just not into the automatics. Or should i ship it back to the builder which i have yet to get a call from...damnit...
Old Jun 25, 2010 | 07:44 PM
bluchev's Avatar
is the builder close to you? if you have someone else dig into it im sure whatever warranty you had will be out the door.
does it slip in 3rd at all?
Old Jun 25, 2010 | 08:12 PM
SPAM HUNTER
yes but its hard to tell it went in but didnt go right in.
Old Jun 25, 2010 | 08:34 PM
budhayes3's Avatar
PT's Slowest Truck
+1, don't let anyone tear into it before you talk to the builder, I know that if it were me who built it and I got it after someone else whored it up I'd be not only pissed but frustrated as it's harder to diagnose once someone else has been in there...
Old Jun 25, 2010 | 08:38 PM
SPAM HUNTER
Hes far away, and if its something simple i will look at it, im why im wanting some input of some easy **** to look at, soleniods, piston, ect...just so i can see if can be fixed without shipping it.
Old Jun 25, 2010 | 08:39 PM
crashlz's Avatar
no reverse...
Case - rear band anchor pin broken or not positioned
Center support - leaking at case or broken
Center support seal leaking
Center support bolt loose, broken or feed hole blocked
Rear band broken worn or not anchored
Rear band apply pin broken worn or not anchored
Rear servo piston binding in case, seal leaking, damaged or worn
servo cover gasket leaking or displaced
servo cover damaged or bolts missing
Check ball missing
list of causes i have found...i think that's from the atsg manual...but unsure as i don't have my book atm
Old Jun 25, 2010 | 09:06 PM
SPAM HUNTER
i found that list to...im meaning easy quick things that can be checked with the pan off not the trans out...trying to avoid pulling it, i think the 3rd gear slip was low fluid, i dont think every part of the trans had filled up yet so it was starved for fluid that made sense to me it was slowly getting better and better driving forward but i didnt want to keep adding fluid to see when i had to drain it anyways.
Old Jun 25, 2010 | 09:09 PM
bluchev's Avatar
well since it wasnt full of fluid in the first place WTF were you doing driving it?
not smart.
fill the thing up and retest.
Old Jun 25, 2010 | 09:11 PM
crashlz's Avatar
hah yeah sorry dont know much about autos yet..but learning will see if i can dig up a flow chart for the 80e
Old Jun 25, 2010 | 09:15 PM
SPAM HUNTER
not smart.
I had 16 quarts of fluid in it, shifted it into every gear several times, and let it heat up, when i drove it it showed full on the dipstick. When i got back it wasnt, but i figured i would have to figure out reverse anyways so i left it.
Not my first rodeo, not trying to be a **** ant just saying.
I think im going to just check all the noids tomorrow, check the reverse piston, a and fill it back up and run it on jack stands to see if i can get the forward gears either working, or get a true symptom...just dont want to ship it for something that i could have looked at.
