Need a replacement flex plate/ Flywheel 60E
Old Apr 30, 2010 | 01:41 PM
  #21
1Bear's Avatar
Chris, I'm using the TCI plate with the ARP M11 x 1.5 crank bolts without issue, so they should work in your application as well. If you do find that you need to go the hardware store route for the converter bolts, like I said you will want Grade 10.9 as they are basically the metric equilvalent of a Grade 8 standard bolt.
Old Apr 30, 2010 | 07:13 PM
  #22
DrX's Avatar
DrX
I agree your crank bolts should be fine. I don't recall if the TCI plate came with them or whether I ordered the ARPs separately.
The converter bolts you were using will be too short. Although the TCI plate is recessed slightly for the bolt heads, that area is still 6mm thicker than the 3mm plate you were using. So you will need bolts that are 6mm longer - add the thickness of the washer to this if you were not using washers before and need them now.
Old Apr 5, 2011 | 08:35 PM
  #23
Tootall's Avatar
bump . . . good info on here . . .
lucas287
31
Jan 12, 2021 06:18 AM
someotherguy
Nov 8, 2017 06:46 PM
chvy=power
Oct 20, 2015 09:08 AM
600 horses
Sep 10, 2015 11:01 AM
xerox17
Sep 5, 2015 01:23 PM
