Need info on gear swap for 2008 GMC...
I would like to do this my self ,how much of a pain will it be and is there anything that I need to look out for? It's a 10bolt with the G80 posi.
I have the G80 in it but have a Auburn unit as well . Which one is better?
I will be going with a set of Richmond 4.10's to replace the 3.42's
Any info from anyone that has done this would be helpful.
also if you havent done them before, I would hesitate on a DD unless I was sure I could do it. if your good with that then do it, just take your time and make sure that the pinion is seated correctly
Ya , not worried about getting in there and doing it just wanted some feed back from someone that has done it that could shed a bit of light on it .
I have a SSTrailblazer for back up if the truck is down for a day or two.
I did a gear change myself 2 yrs ago on my 2000. Here is a link to a write up I did on it including photos of the cantact patterns on the gears when I was setting them up. It took 2 tries to get the shims right. This is not a job for the timid or for those without access to tools and resources. Look at the link it'll give you a little insite into what you can run into.
Bob
http://jimscampingforums.com/forums/...hp?topic=149.0
Bob
Bob
Bob
iregret
Jul 27, 2015 10:32 PM
oharajo
Jul 18, 2015 09:24 PM
04BlackGmc
Jul 16, 2015 04:10 PM
