Need info on gear swap for 2008 GMC...
Old Mar 3, 2009 | 10:51 AM
Default Need info on gear swap for 2008 GMC...
I would like to do this my self ,how much of a pain will it be and is there anything that I need to look out for? It's a 10bolt with the G80 posi.
I have the G80 in it but have a Auburn unit as well . Which one is better?
I will be going with a set of Richmond 4.10's to replace the 3.42's
Any info from anyone that has done this would be helpful.
Old Mar 3, 2009 | 01:30 PM
LS1TRUCKGUY's Avatar
replace it with the auburn. much better unit than the G80. i have a auburn in mine that is almost three years old and is still going strong
Old Mar 3, 2009 | 01:34 PM
BLUES MAN's Avatar
The House is Rockin'
do you have all the tools to install it properly? if not dont do it. a ring and pinion install isnt something to dick around with.....
Old Mar 3, 2009 | 04:14 PM
venomhp's Avatar
also if you havent done them before, I would hesitate on a DD unless I was sure I could do it. if your good with that then do it, just take your time and make sure that the pinion is seated correctly
Old Mar 4, 2009 | 07:12 AM
Ya , not worried about getting in there and doing it just wanted some feed back from someone that has done it that could shed a bit of light on it .
I have a SSTrailblazer for back up if the truck is down for a day or two.
Old Mar 16, 2009 | 09:38 PM
rubrhammer's Avatar
I did a gear change myself 2 yrs ago on my 2000. Here is a link to a write up I did on it including photos of the cantact patterns on the gears when I was setting them up. It took 2 tries to get the shims right. This is not a job for the timid or for those without access to tools and resources. Look at the link it'll give you a little insite into what you can run into.
Bob
http://jimscampingforums.com/forums/...hp?topic=149.0
Old Mar 16, 2009 | 09:42 PM
GMCtrk's Avatar
Sell those Richmonds and buy OEM AAM gears from Ron @ Ron's Machining Service.
Old Mar 16, 2009 | 11:13 PM
budhayes3's Avatar
PT's Slowest Truck
Bob
Great writeup, very informative and entertaining After reading that, I now have a craving for chili though lol
Old Apr 14, 2009 | 06:48 PM
Thumbs up
Did the gears yesterday, what a cake walk. The hardest part was just getting the C-clips out and back in.
Very happy with the results .
iregret
Jul 27, 2015 10:32 PM
Ketis
Jul 23, 2015 12:37 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
oharajo
Jul 18, 2015 09:24 PM
04BlackGmc
Jul 16, 2015 04:10 PM
