Need help with trans problems
Old Sep 11, 2013 | 11:34 AM
askkmb's Avatar
Default Need help with trans problems
Hello,
i just installed a 6.0/4l60e into an 01 s10 and im using the pcm that came with the 6.0. The pcm was for an 4l80e but i changed the tune to an 60e and all the tables that are in the trans section to an 60e. Everything seems to work fine when at part throttle but when i go WOT it doesnt shift. I just goes to the redline to were the fuel cuts and if i release the pedal for about 2 seconds until it takes the second gear i can go WOT again and it does the same again when i get to the third gear. Is there any way i can even use this pcm or do i need to get a 5.3/4l60e pcm? Oh and i used a harness that came from an 5.3/4l60e so i dont think i need to change the pins in the transmission connector unless this pcm has different pins than a 5.3 one. Here is the current tune and also a log. The first to second gear actually did shift but at some where 6000 rpm even if the tune is set at 5600 rpm. The second-third gear didnt shift while staying at WOT only if i realese the pedal.
File Type: hpt
File Type: hpl
Old Sep 13, 2013 | 09:04 AM
askkmb's Avatar
Anyone please.
Old Sep 13, 2013 | 10:41 AM
DrX's Avatar
DrX
I see you are using a 2001 Camaro tune 12202088 (472K). Is the PCM a 2001?
Old Sep 13, 2013 | 11:13 AM
askkmb's Avatar
Actually the pcm comes from a 2001 2500HD Silverado 6.0/4l80e. The tune i posted is the stock tune besides changed from 80e to 60e and some other minor changes but didnt change the OS number. I know "12202088" is from an ls1 but some trucks also have the same OS number.
Old Sep 13, 2013 | 04:08 PM
DrX's Avatar
DrX
Just wanted to make sure the tune and PCM match.
So this is the S10 stock tune or a 2500HD 80E tune converted to 60E? I would just do a full flash of a V8/60E tune of the same OS number. I see Camaro, Corvette, Tahoe......
Old Sep 13, 2013 | 04:33 PM
askkmb's Avatar
The tune is a 2500HD 80e converted to an 60e. Hp tuners is gonna do a segment swap for me now and then i think it should work. I have a few 5.3/4l60e pcm's laying around i could use but i wanted to use this one because i already spend the credits on it. And of course maybe i could learn something i could use in the future.
Old Sep 13, 2013 | 06:25 PM
DrX's Avatar
DrX
Yes, if it is the 80E PCM/tune they need to do the segment swap for you.
Old Sep 13, 2013 | 06:28 PM
askkmb's Avatar
Okay thank you so much!
ferrellrooster
Mar 6, 2025 03:22 PM
Fast86z
Aug 23, 2015 12:35 AM
walledition
Jul 29, 2015 08:54 PM
grantpo
Jul 15, 2015 12:21 PM
lxcoupe
Jul 14, 2015 10:14 PM
