Need help with trans problems
Hello,
i just installed a 6.0/4l60e into an 01 s10 and im using the pcm that came with the 6.0. The pcm was for an 4l80e but i changed the tune to an 60e and all the tables that are in the trans section to an 60e. Everything seems to work fine when at part throttle but when i go WOT it doesnt shift. I just goes to the redline to were the fuel cuts and if i release the pedal for about 2 seconds until it takes the second gear i can go WOT again and it does the same again when i get to the third gear. Is there any way i can even use this pcm or do i need to get a 5.3/4l60e pcm? Oh and i used a harness that came from an 5.3/4l60e so i dont think i need to change the pins in the transmission connector unless this pcm has different pins than a 5.3 one. Here is the current tune and also a log. The first to second gear actually did shift but at some where 6000 rpm even if the tune is set at 5600 rpm. The second-third gear didnt shift while staying at WOT only if i realese the pedal.
Actually the pcm comes from a 2001 2500HD Silverado 6.0/4l80e. The tune i posted is the stock tune besides changed from 80e to 60e and some other minor changes but didnt change the OS number. I know "12202088" is from an ls1 but some trucks also have the same OS number.
Just wanted to make sure the tune and PCM match.
So this is the S10 stock tune or a 2500HD 80E tune converted to 60E? I would just do a full flash of a V8/60E tune of the same OS number. I see Camaro, Corvette, Tahoe......
The tune is a 2500HD 80e converted to an 60e. Hp tuners is gonna do a segment swap for me now and then i think it should work. I have a few 5.3/4l60e pcm's laying around i could use but i wanted to use this one because i already spend the credits on it. And of course maybe i could learn something i could use in the future.
Fast86z
Aug 23, 2015 12:35 AM
walledition
Jul 29, 2015 08:54 PM
grantpo
Jul 15, 2015 12:21 PM
lxcoupe
Jul 14, 2015 10:14 PM
