To much transmission fluid??
Old Apr 5, 2007 | 05:13 PM
ridnlow's Avatar
Default To much transmission fluid??
Looks like i overfilled my transmission by a good bit.. about a inch or 2 past the hot mark.. Do i need to drain out some? that drain plug is a booger.. any ideas??
Old Apr 5, 2007 | 05:16 PM
CHEVRACER83's Avatar
Definitely Drain It....
Taht I Believe Is Gonna Be A Quart Possibly More Over... That Is Way To Much... And Could Come Pourin Out
Old Apr 5, 2007 | 05:28 PM
ridnlow's Avatar
dumb question but could i siphon it out of the dipstick?? drain bolt is giving me some problems..
Old Apr 5, 2007 | 05:33 PM
thunder550's Avatar
High on diesel fumes
I doubt it, the dipstick tube doesn't extend down into the fluid. You might be able to find some thin hose to put down the tube though.
And as stated above, if it's too full it will vent out the top of the trans and cover the entire underside of your truck with tranny fluid. Guess how I know...
Old Apr 5, 2007 | 05:35 PM
spinz71's Avatar
Yes you can but be prepared to sit awhile! I did that by buying a hose small enough to fit in the dipstick tube and let it siphon. Took about 10 min/pint. Have a clear container so you can see how much you've pulled cause trans fluid tastes like when you have to start the siphon again.
Old Apr 5, 2007 | 06:58 PM
Lurius's Avatar
Think tranny fluid taste bad, try swallowing gasoline lol. I had an idiot moment.. Burps tasted like gasoline for a full day!
-Lurius
Old Apr 5, 2007 | 07:20 PM
icedenali's Avatar
how do you check fluid if you have deep pan? i have deep pan and want to change to synthetic, but i have no idea how many quartz to put it in.
i know that stock pan eats like 8quartz...
Old Apr 5, 2007 | 07:28 PM
Basically It Should Still Hit The Same Part On Your Dipstick... Call The Manufacturer... Or Go On There Website And It Should List How Many Extra Quarts Capacity It Adds.... Start There... That Should Get You Close
Old Apr 10, 2007 | 01:05 AM
CashDudeHomie's Avatar
Drill a little hole on the outside part of the drain bolt (dont drill into the pan obviously) then use a hammer and punch to spin the bolt loose. I've had to do this twice now, f**king lousy bolt. Good thing they're like 3 bucks each.
Old Apr 10, 2007 | 07:40 AM
ridnlow's Avatar
My brother bought a cool little pump and pumped out what I didnt need.. thanks for the help guys.. sure runs better on the right amount of fluid
drummer0415
11
Oct 24, 2015 08:16 PM
ice17
Sep 22, 2015 05:18 PM
bluestang50
Sep 21, 2015 08:36 AM
RONIN LSX
Sep 19, 2015 05:33 PM
fortune46x
Sep 16, 2015 08:18 AM
