mid 90's axle question
Old Jan 26, 2007 | 12:09 AM
negativeswitches's Avatar
Default mid 90's axle question
anyone know what the 5 bolt pattern these things had was???
also looking for a flange to flange with and the axle housing flange bolt pattern and spacing (i assume 4 bolt axle housing??)
did most of these trucks get the 8.5" rearend?
i'm looking for this info for my s-10 project (prerunner)
-Erik
Old Jan 26, 2007 | 01:31 AM
chevyguy7802's Avatar
The rear end in my 78 came out of a 87 truck its a 8.5 10 bolt it has the 5x5 bolt pattern, but i think your S-10 has the 4x3/4 pattern i believe you can swap in a F-Body rear end directly
Old Jan 26, 2007 | 08:44 PM
werd i dont want to run adapters that for sure
-Erik
Old Jan 27, 2007 | 09:24 AM
Yeah, 5x5 is the BP for mid 90s 2WD FS trucks. The S-10s have the 5x4.75 BP. If you want a 8.5" S-10 axle you have 3 choices, all out of 2nd gen trucks... one out of a 2WD 4.3/5 sp. truck (optional), a 4WD Blazer/Jimmy (optional), or out of a ZR2 (standard). The reg. 4WD axle is about 3 inches wider than the 2WD, and the ZR2 axle is about 4 iches wider than the reg. 4WD axle. If you're doing a prerunner, the ZR2 axle sounds like it would be a good choice, but I'm not real knowledgable on that prerunner stuff.
Old Jan 28, 2007 | 05:02 PM
yeah that zr2 axle would be great for pre runnin
thanks!
-Erik
BCraven1018
37
Dec 20, 2016 11:46 AM
5.3Caprice
Nov 7, 2015 08:56 PM
spiritfish
Aug 28, 2015 06:46 AM
vipergtrdj
Aug 6, 2015 10:19 PM
USMCvet0311
Aug 1, 2015 07:45 AM
