Lowered Question
Old Dec 20, 2011 | 06:57 PM
TheTerrence's Avatar
Question Lowered Question
about my truck I bought the truck and it was already lowered but I dont know how much or how to tell how much, its a 2006 chevy ccsb on 20s wrapped in 275/45/20 I can post a couple pics if needed. all i know is its way lower then my dodge that was 2/4.5 dropped...
Old Dec 20, 2011 | 07:55 PM
ShredSled's Avatar
easiest way is to take some hub to fender measurements all the way around.
Do you have any rubbing on those tires? Stock, or atleast stock dimension wheels?
If no rubbing, it can't be any lower than 4/7 if on 275/45/20.
Also, look at the back suspension, just takes a quick glance to see if the leafsprings are under (means a flip kit) or over the axle (like stock). If it has a flip kit it will be about 6" of drop out back alone.
Then look at the shackles on the rear of each leafpack. If they have two holes in them, they are lowering shackles, with the bottom of the two adjustment holes being an extra inch of drop, and top leaf bolt hole being an extra two inches.
If no flip kit, check your spring hangers at the front of each leafspring pack connected to the frame. If they are still factory riveted onto the frame, then it wasn't lowered that way with hangers.
Other options would be lowering leafpacks, or just ghetto drop if previous owner removed leafs...
you should also check to see if the frame has been notched over the axle.
Front is a bit harder to recognize, but you might be able to spot taller aftermarket spindles...
Old Dec 20, 2011 | 08:10 PM
heres a couple of pics of the way it sets
sorry for the crappy pics its from my iphone
Old Dec 20, 2011 | 09:52 PM
N/ALS1's Avatar
Clean truck bro. I plan on doing a 2/4 drop whenI get my tranny and 6.0 installed.
Old Dec 20, 2011 | 09:57 PM
.James.'s Avatar
Get center of hub to fender measurements for us
Old Dec 21, 2011 | 02:35 AM
ShredSled's Avatar
hard to tell, and last photo looks like uneven ground... but I'm gonna guess it's around a 2/4, maaaaaybe a 3/6.
Old Dec 21, 2011 | 07:44 AM
.James.'s Avatar
im gonna call maybe a 2/5, 3/5 on it
Old Dec 21, 2011 | 08:19 AM
thanks guys thats what i was wanting to know...
Old Dec 22, 2011 | 01:52 AM
Brandon_73072's Avatar
im going with the 3/5 myself, it looks to sit a lil lower than mine up front and almost identical in rear and mine is 2/5
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
spiritfish
Aug 23, 2015 09:58 PM
USMCvet0311
Aug 1, 2015 07:45 AM
