Let's See Your 2 Piece D/S swaps!!
Old Dec 23, 2012 | 06:34 PM
cdub81's Avatar
Default Let's See Your 2 Piece D/S swaps!!
I'm gonna do a 2 piece DS in place of my 1 pc.
It's a crew cab 4wd. 143.5 WB
If you have pictures of your carrier bearing cross member post em up. I've read a few threads but not that many good pics or they were on a rcsb
Old Dec 23, 2012 | 08:26 PM
texasglock23's Avatar
interested to see it
Old Dec 23, 2012 | 09:11 PM
cdub81's Avatar
Well I have a 5" $$$$$ Driveshaft Specialist shaft now but I'm making some changes so I'm not gonna spend 5-700$ on another 1 piece... I need a longer one so DS specialist said it'd be 400 cause basically it'd new a new core blah blah blah
Old Dec 24, 2012 | 12:45 AM
Blown06's Avatar
8 Second Truck Club
Why the hell would you put 2 where 1 used to be?
Old Dec 24, 2012 | 01:04 AM
lol, the 2-piece is a better design homie, especially for lowered guys, and modded.
Old Dec 24, 2012 | 07:18 AM
cdub81's Avatar
Bump...
Old Dec 24, 2012 | 10:10 AM
I believe a couple guys on customgm did the swap, bagged00 did iirc
Old Dec 24, 2012 | 11:52 AM
blue2003ls's Avatar
I blew up my one piece at the track and used a ECSB 2 piece.
I had to do a couple of changes to make it work but I wanted to keep as many parts fatory GM as possible.
The crossmember was removeable and I set up the u-joint angles to work with my 6" drop in the rear.
Old Dec 24, 2012 | 12:27 PM
cdub81's Avatar
This is what i was looking for. I was wondering how far back the crossmember had to be as I was seeing it was close to the fuel tank. Thanks for the pics. Did you have to do anything special as far as driveline angles? I assume just build the crossmember to suit your angles? Correct?
Old Dec 24, 2012 | 02:00 PM
blue2003ls's Avatar
The centerline of the carrier bearing is 45" from the face of the transmission crossmember and everything else falls in place from there. Luckily I had an ECSB to take measurements for comparison. From what I remember I had 2.5 degrees for the u-joints and 5.5 degrees at the pinion. The only rework I really had to make was rotating the Evap canister similar to how the ECSB.
