junk yard rear end
Well I found a place that has a lot of wrecked GM trucks and SUVs and I was wonting to get a posi rear and with at least 3.73 or 4.10 gears. I have a 02 model silverado and have disk brakes. So I won't to know what all vehicles to ask the guy to check for and what codes they have to check the rear end for what I need. Most likly the gears I won't will be in a 4x4 huh?
4X4's usually cam with the better gears.
I have 3.23's in my base 2x4 WT. Where as a base 4x4 gets 3.73's. Plus my wife and though about a 4x4 for some fun, and my re-search found all most all 4x4's in my area in the NNBS model came with 4.11's. Plus most had posi's in them.
im mainly lookin for something that will be a direct fit with no issues with brakes and whatever else.. think something like a 99-02 silverado z71 will have what i need? or is there any denali or tahoe that came with 4.10 gear ratio in the years that had disk brakes.?
base 4x4's came with 3.42's unless they got an upgrade to 3.73's, z71's got 3.73's a z71 rear end would be a direct swap, as long as you get one that has the disk brakes, the later models have drums. as for a denali or tahoe and avalanches rear end fitting, they are a 5 link setup with trailing arms and coil spring rear suspension, not leaf springs, so definitely not a direct swap.
haaaaa i broke my rear end recently so i got familiar with those codes real quick
for the eaton locker the code is G80 and at least for the 3.73s which is what i have the option code is GT4... if anyone has one of these things laying around that isnt broken they wanna throw my way i would much appreciate it lol
just curious, i have an extended cab 06 with a 5' 8" bed and its super light and noticably quicker then 6' 6" extended cabs, and i was wondering if i should go for 4.10s or would that kill my mileage too much? what kinda mpg you guys getting with those?
shupe
Aug 5, 2015 06:45 PM
zaathur151
Jul 6, 2015 10:57 PM
