I need front and rear gears for 06 4x4 Z-71 1500, what dia of ring gears?
Old Jan 18, 2010 | 08:48 AM
Pontiac Derek's Avatar
Default I need front and rear gears for 06 4x4 Z-71 1500, what dia of ring gears?
Im upgrading to either 4.10's or 4.56's What is the factory fr/rr gear dimensions for my truck and where can I get these at, also do they make a trutrack for my rear? Thanks
Old Jan 18, 2010 | 10:45 AM
1Bear's Avatar
8.25" Front
8.625" Rear
& a big o'le yes
Old Jan 18, 2010 | 06:29 PM
You are awesome! Thank you!
Old Jan 18, 2010 | 07:50 PM
HIPSI's Avatar
I've got some brand new 3.73 yukon gears for the rear and gm gears with approx 60k on them for the front if your intrested...
Old Jan 19, 2010 | 02:32 PM
Thanks MudManMatt but I figure 4.11 will be perfect for my truck and all around performance, if I was racing more id do 4.88's, actually I would now if I wasn't so worried about free way performance, anyone know why 8.5 and 8.6 gears are listed together?
Old Jan 19, 2010 | 05:12 PM
viciousknid's Avatar
Where's the Beef?
because they both fit with .1 of a difference.
Old Jan 19, 2010 | 07:29 PM
1Bear's Avatar
To elaborate a little more, the gears are the same between the two; the bearings are what are different. When you pick up a new carrier, you will need to make sure that you order/receive the bearings for an 8.625”. However before you place your order, make sure what your new carrier will need, as some of the carriers are also for an 8.5” and they will require what basically amounts to adapter bearings. They will have the larger races for the housing with the smaller I.D. on the bearings for the carrier.
Talk it over with the sales-person, as they should be able to ensure you will order the appropriate parts for your application.
Old Jan 19, 2010 | 10:03 PM
Ah I gotcha, thanks 1Bear!
5.3Okasai
Mar 9, 2022 01:07 PM
Steve-O-08
Apr 19, 2018 09:32 AM
Raggedz71
Jul 29, 2016 10:20 AM
jmarkway
Jul 18, 2015 09:23 PM
mrgrim
Jul 8, 2015 08:12 AM
