How much stronger is the 4L80e Vs a 4l65e
Old Sep 13, 2011 | 08:04 PM
Yukon04's Avatar
Default How much stronger is the 4L80e Vs a 4l65e
Just curious as to how much strong the 4l80e is vs a 4l65e also since im in a denali if I was to upgrade to a 4l80e would my awd transfer case bolt up, and even if it did then it will be the new weak link correct?
Old Sep 14, 2011 | 11:18 AM
slowswb's Avatar
pm vince b he will be able to answer your questions
Old Sep 14, 2011 | 11:45 AM
BadAssChevy327's Avatar
stretch your arms all the way out and say " thisssssss much stronger" lol
Old Sep 14, 2011 | 12:24 PM
AndysC3's Avatar
The TC will bolt right up once you swap the input shaft on the TC. Will also need new front/rear driveshaft. and the cooler lines need to be modified.
Old Sep 14, 2011 | 01:11 PM
low2001gmc's Avatar
sounds like a bit of hassle and pricey to upgrade especially if it is stock. i would think it would be best since stock to just buy a good cooler like a tru 40k to reduce tranny temps (main kiler of trannys) and get a tune where you will not only improve the engine performance but can have your tranny shift points and shifts firmed up so the tranny wont seem slugglish. that should help out alot and be sufficient. good luck, rob.
Old Sep 14, 2011 | 02:37 PM
BOTLFED_AWD's Avatar
formerly lamborado (1-12-2012)
qftmft
Old Sep 15, 2011 | 01:07 PM
Yukon04's Avatar
Mods like corvette servos and a shift kit help improve the shifts and reduce the friction correct? If I'm shooting for 550-600 hp my 65 with a little upgrades would be sufficient correct? I would much rather keep the 65 and beef it up rather than tryin a swap.
Old Sep 15, 2011 | 01:42 PM
nonnieselman's Avatar
I didnt have any luck out of a 60/65. I went thru quite a bunch. And most power i ever made was 440rwhp/540rwtq. The stock 80e with a HD2 has lasted longer than all my built 60s put together. I always suggest an 80e, you just cant go wrong.
Old Sep 15, 2011 | 01:49 PM
EVILGMC's Avatar
your thirst for power will grow faster than you can drain your bank account. use the money wisely and do the 80e swap...especially with the weight of a yukon denali.
Old Sep 15, 2011 | 03:00 PM
Yukon04's Avatar
What about my awd transfer case??
