How much gear to offset 4l80 install?
Old Jul 5, 2007 | 03:08 PM
slowec's Avatar
Default How much gear to offset 4l80 install?
I currently run 3.42's. If I install a 4l80, How much of gear in the rear will I need to change to in order to achieve the same 1st gear ratio? Thanks in advance . I am sure somebody knows
Old Jul 5, 2007 | 03:18 PM
RandomHero's Avatar
I get 4.20's which means you would either want 4.30's or 4.10's
Old Jul 5, 2007 | 03:26 PM
BlackGMC's Avatar
Resident Retard
This also might help.
https://www.performancetrucks.net/fo...d.php?t=396210
Old Jul 5, 2007 | 06:42 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Supposedly the higher gear ratio will help the turbo spool better.
Old Jul 5, 2007 | 08:10 PM
slowec's Avatar
I have a 60 turbo on a 6.0...I spool @ idle
Thanks guys, I figured 4.10's 'll do it.
Old Jul 6, 2007 | 08:58 AM
Wilde Racing's Avatar
How do I change this text
might want to check out 3.73. most Turbo guys run or wished they ran 3.73 over the 4.10, but one other thing you didn't say, how big of a tire are you running?
Old Jul 6, 2007 | 09:01 AM
nightrunner's Avatar
Mr. Obvious
pretty sure he's still on stock 235/75/16s, from whati remember in one of his racing threads
Old Jul 6, 2007 | 12:46 PM
slowec's Avatar
He is right. And there gonna get smaller. 275/55/17 or 285/50/18 or 275/60/16 . One of those in the not to distant future.
Old Jul 6, 2007 | 03:52 PM
quicksilverado's Avatar
Keep the gears you have they will make the turbo spool. If you swap to 3.73 or 4.10s it may slow down the spool.
Old Jul 7, 2007 | 10:00 AM
litreddevil's Avatar
Banned
same thing i was thinking if anything put a 50hp shot for the hole shot but a turbo likes back pressure,bind on the motor and that will net a better et check out wildracing z71 excab stock motor trans verter ran 11.4x i think he has 3.42 if i remember right
LCHEE
Oct 24, 2020 04:10 PM
thunder550
Oct 8, 2015 04:53 PM
Greatdivider
Sep 9, 2015 09:52 AM
iregret
Jul 27, 2015 10:31 PM
GM-only
Jul 19, 2015 10:48 PM
