lowering the z71 progress...
Old May 13, 2007 | 11:19 PM
blake2kz71's Avatar
Default lowering the z71 progress...
Iv been looking at the DJM 3/4 kit sitting in my floor for over a month now and finally had time to start this weekend. I might have had the front done by now but I had some problems with the ball joint on the LCA. I finally figured out it wasnt coming out with the axle in. The clearence is way too tight. I got the passenger side done and the driver side mostly done.
So for future reference: The axle has to come out, just loosen the 8? bolts, take the cover off the hub, loosen the bolt(36mm) and just pull it out.
I would hate to know what a shop would charge to replace that ball joint.
Old May 14, 2007 | 07:16 PM
KySilverado's Avatar
Ahhh, bringing back the memories... It's a lot of work but worth it.
Old May 14, 2007 | 07:43 PM
gao8302's Avatar
I just lowered mine also. Its really an easy install. I didnt install rear hangers i just removed the blocks and added the shackles. I used the lowering spindles upfront.
Old May 14, 2007 | 08:27 PM
budhayes3's Avatar
PT's Slowest Truck
I went the cheap easy route...drop keys, 2" shackles and blocks removed. It was a piece of cake. Maybe someday, if I ever see what money looks like again, I'll try spindles or LCA's up front and add some hangers in the rear.
Old May 28, 2007 | 10:22 PM
blake2kz71's Avatar
Default before & after pics. (56k-get drunk and come back)
FINALLY!! Its done. Just need an alighnment and some paint! I still need to play with the torsion bars to get it a little lower but im done for now.
BEFORE:
AFTER:
Old May 29, 2007 | 05:01 AM
03sierraslt's Avatar
Hey man, somone stole your bed. Or you are like me and misplaced it somewhere.
Old May 29, 2007 | 12:04 PM
blake2kz71's Avatar
lol its in the yard, broke. I was gonna get some pics of it but im too embarrased
Old May 29, 2007 | 12:07 PM
Did you take the bed off for the install. Everybody tried to get me to take mine off but I didn't. Would have made some parts easier.
Old May 29, 2007 | 12:11 PM
blake2kz71's Avatar
yeh i did. Then I was by myself and was gona stand the bed on its end so i could clean it and as soon as i picked it up the front corners folded under and broke. I couldnt imagine doing it with the bed on, unless i had a lift.
Old May 29, 2007 | 01:42 PM
litreddevil's Avatar
Banned
dude do you know what a bed side cost and i'll tell you this no matter what you do it will not be right i have fixed one corner 3 times and it is still fcked up
