How many T56 guys is there
Old May 9, 2007 | 07:57 AM
slowrollin93's Avatar
Default How many T56 guys is there
Just wondering how many T56 guys there is here. Might be cool to make a list too of all of us, might throw in what gear your running, what clutch your using, and what kinda power your puttin through them. I will start with mine.
4.56s, ls6 clutch, about 300 rwhp
Old May 9, 2007 | 09:10 AM
vanillagorilla's Avatar
Click the link in my sig. Most of them/us that are regular posters are in there. If I had to guess, there's probably 10-15 regular posters that have done or are doing the swap.
Old May 9, 2007 | 09:35 AM
adam1803's Avatar
Im working on the swap right now, just bought it from vanillagorilla actually.
I'll be running 4.10 gears (for now), Spec stage 3+, and about 450rwhp without the nitrous.
Old May 9, 2007 | 10:27 AM
Tootall's Avatar
I'm "planning" on it, I just have the trans . . . . I'm still gathering up parts. It's going behind a cammed 6.0 and hopefully 4.10 gears
Old May 9, 2007 | 11:34 AM
Quik's Avatar
5 year bitches!
14 bolt 4.88s, Ram VDS rated for 700hp, proshifted t56, 408ci estimate around 500rwhp NA
Old May 9, 2007 | 11:49 AM
TurboGibbs's Avatar
See sig. but 450rwhp maybe.
Old May 10, 2007 | 01:39 PM
kelleyperformance's Avatar
im in the process as well.....
14bolt 3.73s, 500+rwhp, SSR T-56, SSR flywheel/clutch/actuator. and yea- i know, i know the clutch isnt gunna hold up LOL
Old May 10, 2007 | 01:40 PM
Tootall's Avatar
the SSR had a 6 speed option?
Old May 10, 2007 | 09:58 PM
yes sir!! 32 spline, hardened parts, MUCH better gear ratios.... but looks like im the test dummie to see if its actually gunna fit like the f-body trannys do lol. heres a link for some info:
http://www.autoblog.com/2006/12/08/a...andr-part-iii/
Old May 11, 2007 | 06:44 AM
Quik's Avatar
5 year bitches!
with the shifter base sitting slightly higher it might be benifical for you since youll probably end up doing like most of us with consoles do. a stock Fbody shifter might work out for you at stock height and that added height to the shifter base but the shifter will need to be tweaked forward a hair so when you go to grab second it doesnt hit the console
