How to Drop your 4x4
Old Oct 22, 2011 | 02:26 PM
  #21
black04's Avatar
Yeah i had to do the same with mine. Luckily i've never had a problem removing them.
Old Oct 24, 2011 | 12:11 AM
  #22
ShredSled's Avatar
I just remembered, it should also be mentioned in this thread that when going low in the back, like 6-7+ inches, you will need to have your rear driveshaft shortened. I believe mine was shortened 1" and high speed balanced at the same time.
Old Dec 21, 2011 | 03:43 PM
  #23
X Lady Killer X's Avatar
Registered User
whats the total drop you have?
i bought my truck with a 6" lift and now i want to go the other way... i like how yours looks
Old Dec 21, 2011 | 09:56 PM
  #24
ShredSled's Avatar
were you asking me? Mine is at 4.5/7.
oh, and btw.... thanks again for making this thread, Bud, you'll be sorely missed around here....
Old Dec 31, 2011 | 06:33 PM
  #25
Frostflowz's Avatar
02 z71
spindles and keys - flip kit and shackles
Old Dec 31, 2011 | 09:03 PM
  #26
TIM Z's Avatar
11 sec. Truck Mod
Wow That sits nice!
Hows the ride?
Any wheel hop with the rear set up?
I'd like to closely mimic your ride heidth, i just have stock keys de-cranked and a belltech 2'' drop shackle/ removed factory block.
Old Jan 1, 2012 | 06:21 PM
  #27
Frostflowz's Avatar
Thanks!
The ride is great actually, it's firm. No wheel hop but I also have helper bags in the bag @ about 80 psi.
Old Jan 1, 2012 | 07:25 PM
  #28
ShredSled's Avatar
what is it, flip kit and lift shackles? Doesn't look low enough for flip kit to me.... but then again, dayum 80psi in your helpers at all times!!?
I have mine dialed with the flip kit, lowering shackles, and front leafspring clamp and pinion aimed downward a bit, so not even a hint of wheel hop. I think axle wrap is pretty well minimized with a setup like this too. No need for helper bags either. Only thing I'd like to do next is 4-link and double adjustable coilovers!
Old Jan 2, 2012 | 01:06 PM
  #29
Frostflowz's Avatar
It's a flip kit and drop shackles. I'm going to put the stock shackles back in so I can air down the bags a bit..
Old Jan 2, 2012 | 09:45 PM
  #30
ShredSled's Avatar
whaaaat that's supposed to be 7“ drop out back then! That's where I'm at and I nearly tuck tire out back with 275/45/20. Those bags must be holding up your *** end a good 2-3"! I can't imagine the ride being all that good unless you have a heavy load in the bed.
