How can I tell what gears I have?
Old Aug 24, 2010 | 10:22 AM
slpsilverado's Avatar
Question How can I tell what gears I have?
Sorry if this is a dumb question. I'm not a mechanic. I did a search, but could not find what I was looking for. I did find some stuff via Google about RPO codes, but didn't know what to look for.
Truck specs in signature. Other than crawling underneath the truck, is there a way to tell what kind of gears I have installed? As far as I know, the drivetrain is all stock.
I get about 18mpg, probably 80% highway driving. I've been told to do a gear swap for better takeoffs, but I need to know what I have currently to know if it is worth the $$$$ to change. I don't want a massive loss in my MPG, but I'd take a small hit if it would make the takeoffs better.
Old Aug 24, 2010 | 10:45 AM
TX Tahoe Z71's Avatar
You could back into it, (4L60E gear ratios: 1st 3.059, 2nd 1.625, 3rd 1.000, 4th .696, Reverse 2.294), http://www.car-videos.net/tools/speedrpm.asp. Plug in your rpm you usually turn at 70mph in 4th with the converter locked, then plug in 3.23, 3.42, 3.73 and 4.10, when you get 70mph as your speed in 4th, that's your ratio.
But I'm sure the label in your glove compartment tells you, I just don't know the code to look for, someone else might.
Old Aug 24, 2010 | 10:52 AM
walledition's Avatar
Look for one of these numbers in ur glow compartment
gu5=3.23
gu6=3.42
gt4=3.73
gt5=4.10
Old Aug 24, 2010 | 10:58 AM
gu5=3.23
gu6=3.42
gt4=3.73
gt5=4.10
I guess if you wanted to do it the easy way
Old Aug 24, 2010 | 11:04 AM
Dang. Using both methods, I just learned that my truck has 3.23s .
Well, at least my gas mileage is good.
If I change to 3.73 or 4.10, what kind of performance gain/mileage loss can I expect? My tires are currently 245/70/17, but I plan on going with some OEM 20s eventually...probably 275/55/20. I would get a tune after wheel/gear change, too.
Old Aug 24, 2010 | 11:11 AM
If you don't do a ton of highway driving, 4.10's will give you the best seat of the pants improvement, but if highway mpg is a concern, 3.73's are good. I run 3.73's and they are great in the city and on the highway.
EDIT: Here's a good thread: https://www.performancetrucks.net/fo...d.php?t=467850
Old Aug 24, 2010 | 11:38 AM
Highway mileage is important to me. I have a 64 mile commute 5 days a week.
Anyone...what would be the best gear setup for my current tire size and best gear setup for OEM 20s? (Sizes mentioned above) I would like better takeoffs, but MPGs are relatively important to me. This is a DD.
Old Aug 24, 2010 | 01:56 PM
Fastcount03's Avatar
http://www.grimmjeeper.com/gears.html
Here is a link that will tell you what final drive and speeds at rpms to help you decide. You can also compare 2 setups side by side.
Old Aug 24, 2010 | 02:06 PM
Any idea what specific kind of transfer case and underdrive my truck has?
Old Aug 24, 2010 | 02:08 PM
You're 2wd, so you don't have one. You could probably enter "1" and it would work.
