Help me out guys
Finally got my turbo kit done and somewhat tuned. First time 1/2 throttle boost pull and it blows the tires off. Well one tire, I'm pretty sure I have the non posi rear end.
2005 2WD 4.8 RCSB
s475 turbo
1. What rear do I have? 10 bolt 8.6?
2. Should I just put a tru trac in it?
3. Anything else that should be done besides better tires obviously?
Thanks guys.
2005 2WD 4.8 RCSB
s475 turbo
Thanks guys.
2005 2WD 4.8 RCSB
s475 turbo
1. What rear do I have? 10 bolt 8.6? - YES!!!
2. Should I just put a tru trac in it? - YES!!!
3. Anything else that should be done besides better tires obviously? - Some kind of traction control / Assassins / CalTracs / Something...
Thanks guys.
2005 2WD 4.8 RCSB
s475 turbo
Thanks guys.
With a 4/6 drop using a 20" wheel, a 275/45/20 is maxed out with a little rub on hard dips and bumps. That tire has a diameter of 29.7 so if you are using a different wheel size that will help you dial in a tire size.
https://tiresize.com/calculator/
https://www.youtube.com/watch?v=4pz11p238dc
295/55/15 should be just fine then.. Thanks for the help. Your truck looks awesome.
