Help me out guys
Old Jul 2, 2018 | 02:17 PM
Burnett03's Avatar
Default Help me out guys
Finally got my turbo kit done and somewhat tuned. First time 1/2 throttle boost pull and it blows the tires off. Well one tire, I'm pretty sure I have the non posi rear end.
2005 2WD 4.8 RCSB
s475 turbo
1. What rear do I have? 10 bolt 8.6?
2. Should I just put a tru trac in it?
3. Anything else that should be done besides better tires obviously?
Thanks guys.
Old Jul 2, 2018 | 02:27 PM
Atomic's Avatar
I have a gauge for that
Do you have the G80 code in your glove box? Either way an upgrade POSI is a good idea. I like the eaton LSD but the trutrac is popular also.
Old Jul 2, 2018 | 02:51 PM
Burnett03's Avatar
I'll take a look. I doubt I have the G80 code. I think I just have the regular non posi.
Old Jul 2, 2018 | 03:05 PM
darkirish63's Avatar
2005 2WD 4.8 RCSB
s475 turbo
1. What rear do I have? 10 bolt 8.6? - YES!!!
2. Should I just put a tru trac in it? - YES!!!
3. Anything else that should be done besides better tires obviously? - Some kind of traction control / Assassins / CalTracs / Something...
Thanks guys.
Short but to the point answers...
Old Jul 2, 2018 | 03:22 PM
Burnett03's Avatar
That's what I wanted, thanks! What size tires can fit under these trucks without cutting? 295, 305?
Old Jul 3, 2018 | 09:20 AM
Have you lowered it, yet?
Old Jul 3, 2018 | 09:40 AM
Burnett03's Avatar
That's next on the list.. Probably a 4/6 drop.
Old Jul 5, 2018 | 08:39 PM
RedXray's Avatar
100% Redneck
With a 4/6 drop using a 20" wheel, a 275/45/20 is maxed out with a little rub on hard dips and bumps. That tire has a diameter of 29.7 so if you are using a different wheel size that will help you dial in a tire size.
https://tiresize.com/calculator/
Old Jul 6, 2018 | 10:13 AM
Burnett03's Avatar
https://www.youtube.com/watch?v=4pz11p238dc
295/55/15 should be just fine then.. Thanks for the help. Your truck looks awesome.
Old Jul 7, 2018 | 01:05 PM
terravast4's Avatar
I have a 3/5 drop and I have ran a 305 before but there are more options in the 295 range
