Help explain 4L60 failure.
Old Dec 10, 2012 | 10:11 PM
TG02Z71's Avatar
Originally Posted by silverz28camaro
Definitely post up what you find during teardown, but I'm wondering if something happened in the low/roller clutch area..
How did the truck shift before the issue? was it bang shifts? or did it hit hard going into gear from nuetral...I know this has caused issues in the past where to much Park/Nuetral pressure into gear has blown out snaprings on these transmissions
The truck had no issues going from neutral to drive or from park to drive that was always smooth. When you hit 2nd gear at more than 30-40% throttle it would chirp the tires going into 2nd gear. I had about 20k miles on the trans and most of that was pretty light use since I had either cracked a piston or ring land and it has been pushing boost into the crankcase for years. I used my company car for soo long I just never had the time or money to fix the truck, plus getting divorced and being broke for several years did not help.
Thinking about bailing on the whole modding the truck thing once and for all.
this thing has cost me way too much money over the years. Maybe I should have divorced my truck along with the ex wife??
Old Dec 10, 2012 | 11:31 PM
silverz28camaro's Avatar
Originally Posted by TG02Z71
The truck will not roll back even in neutral. I jacked the back up just to move it. When I had the back in the air I tried to rotate the wheels. Feels like an unusual amount of resistance to make them move at all.
I checked the fluid for the hell of it, its full and does not smell of burnt clutch at all.
I am starting to think something is locked up but I don't know enough about an automatic transmission to even guess. Could the converter have went out? Would that even effect it at all?
even if the converter went out it should still roll....does it only not roll backwards? Can you pull the driveshaft to make sure nothing funny is going on with the brakes or rearend?
Old Dec 11, 2012 | 06:52 AM
Vince B's Avatar
I'm going to say that the clutches in the input drum are all welded up. This would cause a tie up in reverse.
Old Dec 11, 2012 | 07:27 AM
TG02Z71's Avatar
I'll be pulling the rear drive shaft possibly tonight. I have to so I can at least roll it around. I don't think it the rear brakes as I have never had an issue with them since new but you never know I guess.
Old Dec 11, 2012 | 07:55 AM
chevrolet all the way's Avatar
Vince beat me to it. the forward clutches in the bottom of the input drum i bet are the culprit here.
Old Dec 23, 2012 | 08:49 PM
BIGDADDY1969's Avatar
Any update on this issue? I just towed my 08 in with the similar problems. Going to start looking for options right now to replace the 4l60e. Not sure if its worth fixing .. im wanting upgrade anyway.. gunna depend on cost to repair it..
Update on yours TG02Z71??
Old Dec 29, 2012 | 01:37 PM
TG02Z71's Avatar
No updates other than taking the drive shaft out. Truck rolls now so its not the drive shaft or the rear end.
I have no desire to lay under my truck when its 25 degrees out so its gonna be a long time until I get this all sorted out.
When I do tear it out and apart I will definitely post pics and finding.
I just bought a new car a week ago that gets 30+ mpg so the truck will be sitting either way.
Old Dec 30, 2012 | 04:06 PM
When you say it wont roll back is that with the truck running or turned off?
Old Dec 30, 2012 | 07:51 PM
TG02Z71's Avatar
Off or on, in neutral.
Silver8ado
13
Oct 21, 2024 09:09 AM
Blwn99x
Mar 24, 2023 11:14 AM
Aaron Arceneaux
Dec 21, 2015 02:54 PM
11MPG
Sep 8, 2015 04:52 AM
lo&sloSierra
Jul 19, 2015 10:56 AM
