Help Blew Up Driveshaft........
Old Mar 27, 2006 | 07:23 PM
phasemaster1's Avatar
Default Help Blew Up Driveshaft........
Well went to dyno my truck and im still shaken. Numbers were not good on third run driveshaft went boom. It ripped in two front went one way i had to jump and busted my *** when back piece came towards me.That **** sucked thought that was it.Yeah 3rd gear pull dont know what happend. how do i know if tranny is good makes nasty noise when in park but i put it in neutral and its quiet.How do i measure for a new driveshaft and why do they want to run trucks in 2nd gear?
Old Mar 27, 2006 | 10:39 PM
hog's Avatar
hog
Yet another victim of what happens when a truck with a REMOVED 99 mph speed limiter is taken to redline in 3rd gear.
I am a firm beleiver in 2nd gear dyno runs, much much safer.
They want to dyno trucks in 2nd gear simply because the driveshaft doesnt get spinning anywhere near the rpm it does in 3rd gear. These truck driveshafts were designed to turn no faster than 99 mph with 4.10 gears and 2wd tires(28")or a driveshaft rpm of 4400. All the other combos(3.73 or 3.42 and 4wd tires) will make the driveshaft spin at less rpm. The problem is only compounded when lower gears and tires are used.
There are lots of guys removing the speed limiters and revving to 6200 rpm in 3rd gear or 125 mph(with 4.10 gears, 28" tires) on the dyno.
And some on the street who run their trucks to say 5300 ENGINE rpm in OD which is 6900 driveshaft rpm, that gives you 153 mph.
GM TRUCK driveshafts were never designed to turn that fast. The Camaro, Vette driveshafts are another story.
Thats why I have a custom steel shaft in use.
I am glad you are OK.
peace
Hog
Old Mar 27, 2006 | 10:48 PM
James B.'s Avatar
I also have a custom fabricated steel driveshaft. It's 3.5" diameter, weighs 24 pounds (heavy ****) and has fixed yokes at both ends. The shaft itself is splined.
Why the seemingly overkill for this truck? Well, I have 4.56:1 gears and have my speed governor set at 130mph . I've hit the limiter plenty of times during some WOT blasts. That's over 6600 RPM for that driveshaft. I wanted to know the driveshaft was up to the challenge.
This is it on the bottom:
Old Mar 28, 2006 | 01:42 AM
AintNoHo's Avatar
Scary to say the least. Often when the shaft goes it will break the diff housing end or tranny end/xfer case. Look for cracks and leaks. Also a good lesson on why to have a driveshaft loop. Only cost $20 at Summit and a good investment.
Old Mar 28, 2006 | 01:08 PM
04Denali's Avatar
Can someone post a picture and part number for the driveshaft loop from Summit.
Thanks
Old Mar 28, 2006 | 01:47 PM
bud8fan's Avatar
welcome to the not want to be in it club....i also twisted mine in two and now have a hd drive shaft....
Old Mar 28, 2006 | 01:50 PM
dc_justin's Avatar
Hello Dave
Anybody happen to know the stock driveshaft RPM limit on the SS? It's an oversized aluminum one...
Old Mar 28, 2006 | 01:54 PM
white1's Avatar
Is it any different in a RC4wd? My drive shaft is only about 4 ft long at the most.
Old Mar 28, 2006 | 06:23 PM
well started truck up in neutral and my abs light came on guess i have to check system
Old Mar 28, 2006 | 06:52 PM
speedometer shows in neutral 10 mph an dsince no drive shaft speed sensor acting up
