Gov-Loc or Tru Trac on snow and ice
Have 92 1/2 ton 4X4 pickup. Currently has an open carrier in the rear. Was wondering what carrier is better on snow and ice. The truck is something to get me back and forth to work in the winter.
If you're not going to do any drag racing in the summer with it, then go with the gov lok by all means. It will outperform any torsen style differential by leaps and bounds on snow and ice. True tracs work off the torque applied to the right rear wheel, that torque amount is multiplied by the bias (usually 1.5) to the left rear. If you have ZERO traction on the right rear, 1.5 times 0 equals what? ZERO. The left rear won't spin and you have to apply the emergency brake to simulate traction. The gov lok will do just the opposite. IT LOCKS when it's supposed to.
They hold up well if its a pretty stock truck with 16" or 17" rims. 20"s can tweek them. Mines done. It hasn't locked for almost 100,000mi now. When I get around to changing it out im going with a tru trac but in FL we dont see snow and ice.
I had a G80 in my truck and swapped it for a True Trac. I actually like the TT better. With the G80, yes it locks, however it unlocks at 30mph or so. In the snow it's really easy to get the wheels spinning past 30mph. I found it would constantly lock and unlock, lock and unlock, causing the rear end to swing out some when it was locked, then come back straight when it unlocked and was 1 wheel peel.
I like the TT better because it's predictable. I know when it will spin both wheels and slide the rear end out.
