GMT900 Front Coilover Question
Old Apr 20, 2013 | 10:49 PM
tiffo60's Avatar
Default GMT900 Front Coilover Question
I've been going thru QA1's entire catalog, which coilover shocks will swap on the front?
These?
3rd & 4th Generation F-Body Single Adjustable Pro Coil System | Camaro & Firebird Strut & Shock Kits | QA1 Suspension
Old Apr 21, 2013 | 10:28 AM
SLCviaAK's Avatar
Have you contacted Fox shox or king racing? They make bolt in coilovers, although they are for lifted apps. They could probably make some for a lowered app too. That's what I will eventually do, just haven't gotten around to it.
Old Apr 21, 2013 | 01:13 PM
tiffo60's Avatar
About $1200 a set iirc. Little more than I had in mind lol
Old Apr 21, 2013 | 01:15 PM
Atomic's Avatar
I have a gauge for that
Just measure from bolt to bolt at what ride height you want and match that up to the qa1 catalog...
Old Apr 21, 2013 | 01:20 PM
tiffo60's Avatar
I've done that, it's what upper mounts and spring mounts that will work that I'm not sure of
Old Apr 21, 2013 | 01:39 PM
Atomic's Avatar
What types of mounts are on the nnbs?
With QA1s you will probably need to go to an aftermarket spring. Although im not 100% sure because ive never delt with one of the nnbs coilover springs.
Old Apr 21, 2013 | 01:46 PM
tiffo60's Avatar
Old Apr 21, 2013 | 01:50 PM
tiffo60's Avatar
Old Apr 21, 2013 | 06:26 PM
Atomic's Avatar
Alright so stud upper and eyelet lower.....Stocker Star Shocks | Stock Mount Non-Coil-Over Shock Absorbers | QA1 Suspension
Take your pick...you want your ride height to be approximately in the middle of the shock range.
Old Apr 21, 2013 | 06:59 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Strut upper mount and t bar lower mount. Ive looked as well because my belltech front struts ride like crap. Those look like they may work atomic^^^
