GMT900 Front Coilover Question
I've been going thru QA1's entire catalog, which coilover shocks will swap on the front?
These? 3rd & 4th Generation F-Body Single Adjustable Pro Coil System | Camaro & Firebird Strut & Shock Kits | QA1 Suspension |
Have you contacted Fox shox or king racing? They make bolt in coilovers, although they are for lifted apps. They could probably make some for a lowered app too. That's what I will eventually do, just haven't gotten around to it.
Originally Posted by SLCviaAK
(Post 5094831)
Just measure from bolt to bolt at what ride height you want and match that up to the qa1 catalog...
Originally Posted by Atomic
(Post 5094871)
What types of mounts are on the nnbs?
With QA1s you will probably need to go to an aftermarket spring. Although im not 100% sure because ive never delt with one of the nnbs coilover springs. |
1 Attachment(s)
Alright so stud upper and eyelet lower.....Stocker Star Shocks | Stock Mount Non-Coil-Over Shock Absorbers | QA1 Suspension
Take your pick...you want your ride height to be approximately in the middle of the shock range. |
Strut upper mount and t bar lower mount. Ive looked as well because my belltech front struts ride like crap. Those look like they may work atomic^^^
