Gears and locker's for a Z71
Old Jan 16, 2006 | 10:08 PM
closet red neck's Avatar
Question Gears and locker's for a Z71
Who is the best (or one of the best) manufacture's that manufacture gears and a locker (just the front) for my truck?? I want to R&R the front also. I'm going with the Tru-Trac for the rear, so what can I do for the front to make it more bullet proof? I'm mean 4:10's in front and rear but what kind of setup do I need for the front??
Thanks,
James
Old Jan 16, 2006 | 10:52 PM
The only locker that is available for the front is the Eaton E-Locker, cost about $800. As for the gear set stay with the oem.
Old Jan 16, 2006 | 10:56 PM
So if I want 4:10's, get oem 4:10's??? I have 3:73:'s now.
Thanks
James
Old Jan 16, 2006 | 11:05 PM
That's right, somebody will chime in if they know of a better way to go.
Old Jan 16, 2006 | 11:11 PM
smooth_addictions's Avatar
i agree. i do think that you can drop an air locker in there too if you like. but i would go with the oem gears.
Old Jan 17, 2006 | 12:18 AM
hog's Avatar
hog
Richmond gears by far, I have broken 3.08's, 3.42's 3.73 GM gears and I have broken a set of Richmond 4.10's but the Richmonds lasted the longest, by a long shot. Thats kinda weird becaus ethe 4,10 ratio is weaker than the higher gears are, this is due to the small pinion gear. if you lay a 4.10 and 3.08 pinion gear next to eaxch other, the dif. is quite large.
My Richmond 4.10's survived 3 Powertrax lockrite failures as well as an open dif. failure in which the carrier split right in 1/2, it was literally in 2 halves. I cleaned up the rough edges of teh Richmond ring and pinion and reinstalled them and got another 100,000 kms out of them, which included roughly 150 1/4 mile passes and severl hundred o-60 mph WOT acceleration runs.
My Richmonds were quiet, they never howled, the 4.10 Richmonds finally broke when I did a torque converter stall test in my driveway, I had teh e-brake and foot brake on tight, put thetrans in 1st and went to WOT. the V6 S10 TC flashed to 2500 rpm then I heard a noise so I let off right away. I drove forward and heard a che ching che ching noise. I had taken off a few pinion teeth. Those gears owed me nothing, they had over 250 1/4 mile passes and over a 1000 WOT acceleration runs in remote areas on pavement on them.
Well theres my opinion on differential gears.
peace
Hog
Old Jan 17, 2006 | 04:20 PM
black4x4's Avatar
there is no locker for a 8.25 ifs housing there is one for the 9.25 one thoe. and your best to leave the front open if you want it as strong as possible
Old Aug 3, 2007 | 03:16 PM
How hard is it to change out the 8.25 for the 9.25?
Old Aug 3, 2007 | 03:28 PM
ZZebes's Avatar
Go with Yukon Gears
Old Aug 3, 2007 | 06:10 PM
truckmann's Avatar
Lockers in the front end make steering not fun... I put a powertrax in the front of my old 1984 chevy and it was a mistake. It was my off-road play truck and there really was no benefit at all to having the locker in the front. It just put way too much stress on the front axle u-joints and I would imagine will do the same to CV joints. Steering while in 4wd was crap and over worked the power steering pump.
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
Noah Burns
Oct 5, 2015 06:46 AM
wrb002
Aug 25, 2015 03:56 PM
97aztecgt
Aug 13, 2015 02:11 PM
