Gear selection. 4l60e and 27-29" tires
Old 07-25-2016, 11:13 AM
pewter00's Avatar
Default Gear selection. 4l60e and 27-29" tires
Needing help selecting gears. In process of going in with a 5.3 (heads, cam, nitrous) with a 4l60 behind it. My normal run around wheels will be 20" with a 275/40/20 (28.62 height) and when at the track it's looking like I will be on a 27 or 28" radial. I was originally thinking a 4.10 but now I'm kind of wondering if I should go 3.90? I don't want to run out of gear at the track. Ordering the Tru Trac and gears today if I can get this nailed down.
Any help is appreciated.
Old 07-25-2016, 11:21 AM
madmann26's Avatar
With those heavy *** 20s, you'll want the 4.10s.
Old 07-25-2016, 12:34 PM
pewter00's Avatar
The truck isn't a daily. The 20's will literally just be for cruising around on occasion. I'm wanting to have it setup to cater toward the drag setup.
Old 07-25-2016, 12:44 PM
madmann26's Avatar
If it's mainly a drag setup, I'd look at 4.56s.
Old 07-25-2016, 02:38 PM
pewter00's Avatar
how do I figure out if I will run out of gear if I'm running a 27" tall drag radial?
Old 07-28-2016, 07:00 PM
10 Second Club
At what RPM does peak HP occur? What do you expect for MPH out of it? Do you know the % if converter slip?
For example.... 27" radials, 4.10 gears, theoretical 116 MPH with a fairly efficient converter. My math puts that setup between 6000-6300 at the stripe. HTH
Old 07-30-2016, 10:38 AM
Fast355's Avatar
With that setup you will want 4.56s for the 4L80E that will come when you get tired of blowing up 4L60Es.
dgcustomz
Ford Parts Classifieds
03-06-2016 02:59 PM
dgcustomz
03-06-2016 02:56 PM
BwalterChevrolet
02-24-2016 08:18 AM
oxidizr
05-06-2002 08:04 AM
bctruck
03-06-2002 11:15 PM
Quick Reply: Gear selection. 4l60e and 27-29" tires
