99 5.3 head swap
Old Feb 23, 2016 | 07:19 PM
BwalterChevrolet's Avatar
Default 99 5.3 head swap
So I have a 5.3l iron block stock bottom end with stock 862 heads
Small comp cam ls6 springs couple other things
In a 99 silverado
Future plans of goin turbo. So what kinda heads
Can I throw on this thing without having to make huge
Changes to the rest of the motor. Also a budget build.
Will a set of ls1 heads do the trick?
And yes I'll probably try to get ahold of a better cam for the set up
Thanks fellas
Old Feb 23, 2016 | 09:56 PM
LARRY01Z28's Avatar
you can get a set of 243 heads or you can port the stock 862 heads, with a valve job.
keep in mind you will have to buy gaskets and head bolts also.
Old Feb 24, 2016 | 08:18 AM
Currently has all ARP bolts but would like to do head studs eventually to cover my ***
JordanH
Jan 18, 2016 02:53 PM
91LT16SpeedFormula
Jan 17, 2016 06:16 PM
shrike
Jan 6, 2016 05:23 AM
Low97tahoE
Jan 1, 2016 09:39 PM
lsxperformance
Dec 22, 2015 10:32 PM
