Gear selection. 4l60e and 27-29" tires
Needing help selecting gears. In process of going in with a 5.3 (heads, cam, nitrous) with a 4l60 behind it. My normal run around wheels will be 20" with a 275/40/20 (28.62 height) and when at the track it's looking like I will be on a 27 or 28" radial. I was originally thinking a 4.10 but now I'm kind of wondering if I should go 3.90? I don't want to run out of gear at the track. Ordering the Tru Trac and gears today if I can get this nailed down.
Any help is appreciated.
At what RPM does peak HP occur? What do you expect for MPH out of it? Do you know the % if converter slip?
For example.... 27" radials, 4.10 gears, theoretical 116 MPH with a fairly efficient converter. My math puts that setup between 6000-6300 at the stripe. HTH
oxidizr
May 6, 2002 08:04 AM
