G80 out...what in?
Old Feb 7, 2007 | 05:32 PM
bgray's Avatar
TOTM: June 2007
k...been doing some more research...and It seems to be Eaton Detriot Tru Trac or the Eaton LSD....so i got that down
Now at the risk of sounding like a retard....I already has 3:73..but thinking of doing 4.10's....if i choose 3:73 will I have to buy another gear set? can I reuse stock stuff??
any anbody know where I can find part #'s?
Old Feb 7, 2007 | 05:49 PM
KySilverado's Avatar
GM 10 bolt, 8.5/8.6, 30 spline differential. You will have to have a new ring and pinion if you change gears, not if you keep the 3.73's. I recommend AAM (OEM) gears. You could probably re-use your carrier and pinion bearings and races... if you can get them off without damaging them. I recommend new ones. I recommend new bolts for the ring gear. I also recommend having a professional install and setup your rear end.
The Detroit True-Trac part # is 913A48L
Old Feb 7, 2007 | 06:15 PM
Phantom's Avatar
11 Second Club
TRucks got 3:73 is it now....how much worse is gas mileage with the 4:10's??
I thought people were gettin better gas mileage with the 4.10's
Old Feb 7, 2007 | 07:13 PM
Lord Aries's Avatar
I love my Eaton LSD with 4.56 gears...
Old Feb 7, 2007 | 11:39 PM
onebadrubi's Avatar
4.10 if you do more town driving. 3.73 if you do more highway.
The true trac instead of having clutches engage the positive traction it has gears. I can throw my *** end around at will. But if I dont want to its all good and is just as DD as my G-80 was.
Old Feb 7, 2007 | 11:58 PM
bluecajun5.3's Avatar
11 Second Truck Club
i did my eaton lsd and motive 4.10's install @ 25k mi.
first gear set and differential ive ever set up.
the combo now has 46k mi. on it and never had one problem or complaint.
pulls consistent 1.75 short times and a best of 1.73
Old Feb 8, 2007 | 02:07 AM
Mr. Sandog's Avatar
My vote is for the Eaton LSD.
Old Feb 10, 2007 | 02:40 PM
bgray's Avatar
TOTM: June 2007
Im thinking some tru trac..and maybe 4:10's..not sure...I do highway a fair bit...THe truck will only see less than 5000km a year...its alreayd got 3:73's...so its not like I have a slouch gear in it..works good.
Thnks..gonna probably ahve my mechanic do it cause I dont know how to set it up properly etc
Corvette454l88
Sep 1, 2016 01:24 AM
97aztecgt
Aug 13, 2015 02:11 PM
vmaxpro
Aug 8, 2015 10:49 PM
02sierraz71_5.3
Jan 19, 2005 03:04 PM
renegade4e
Jan 10, 2005 04:49 AM
