Is it fried? 4l65e
Old Jun 8, 2016 | 08:22 PM
hrobb256's Avatar
Default Is it fried? 4l65e
03 Silverado ss 75k miles installed a small stall converter new cooler corvette servo and a trans go hd shift kit. Shifts through all gears fine 1-2 was kinda harsh so today I got my laptop and adjusted 1-2 part throttle shift. I got it where I like it I have drove it very little and babied it when I did. Well I pushed it some today at about 50-75% throttle when it hit second it slipped rpm went straight to 5k before I let out. I felt good about shift kit and servo install but doesn't mean I didn't miss something. I need some ideas to help me troubleshoot this thing any input is appreciated
Old Jun 8, 2016 | 09:21 PM
Wolftrk99's Avatar
What did you do to adjust it in the tune??? If shouldnt go from harsh to slipping!!
Old Jun 8, 2016 | 09:35 PM
hrobb256's Avatar
once I got it going into 2nd at nice pressure I started pushing it harder I haven't really got in it until today so I don't think it is tune related but I am no pro tuner either
Old Jun 9, 2016 | 06:21 AM
About20ninj45's Avatar
Post the tube or tell him what you did to it so he can give a better diagnosis...
Old Jun 10, 2016 | 11:02 AM
hrobb256's Avatar
Ok I know it's not a tune related issue but I do have a thought I purchased a complete vette servo ready to drop in. My question is could it be possible that with using new rod could my band adjustment be off enough to cause the slip?
Old Jun 10, 2016 | 12:08 PM
Wolftrk99's Avatar
Yes i the pin is too short it will cause the band to not engage at all, or engage enough to wear the band but not hold the drum... You should have air checked the serbo when you put it in to make sure it was actuating and applying the band....
Old Jun 10, 2016 | 12:26 PM
tgui's Avatar
I thought I've read about people messing up the seals on the servo when installing as well.
Old Jun 10, 2016 | 12:55 PM
hrobb256's Avatar
thanks it's going to the shop I'm done with it but took the servo back out and seals were good and pin looked to be same installed it all and it will hold to about 5k before it slips now. Am I thinking right servo tightens band and band does 2-4 right so that could very well be my problem??
Old Jun 10, 2016 | 12:57 PM
Wolftrk99's Avatar
There is a bunch of reasons why second would slip, bad solenoid, lack of line pressure, leaking servo seal(s), incorrect servo pin length, cracked case, stuck checkball burnt band, burnt reverse input drum... Hell a bad sunshell could cause no 2nd gear....leaking valve body gasket.... Incorrect valve body torque.... List goes on and on!!!
Old Jun 10, 2016 | 12:58 PM
Wolftrk99's Avatar
Yes but the band is more so ised for 2nd than 4th, the 3-4 clitches take most of the 4th abuse.....
Time2Kill
Dec 29, 2020 11:36 AM
Funkster
Jun 3, 2016 04:26 PM
25hdtankhauler
Apr 2, 2016 10:20 AM
Furdkiller
Mar 27, 2016 07:37 PM
1999Firehawkls7
Mar 23, 2016 01:49 PM
