Fly wheel problem
Old Feb 9, 2009 | 07:22 PM
Default Fly wheel problem
Alright so i went to put the torque converter bolts in and not to my suprise somthing else wasnt right. I see the bolt patern on my 6.0 flywheel is bigger than the 4l60 torque converter. The tranny is out of a 99 z28 so i geuss my question is what fly wheel do i need or can mine be modified to work.
Old Feb 10, 2009 | 10:49 AM
03sierraslt's Avatar
Dont you have a 4L80 Trans? Oh wait, what is this going in?
Old Feb 10, 2009 | 10:53 AM
KySilverado's Avatar
If I understand this correctly.... you have a 2003 2500HD 6.0L. You pulled the 4l80E out of it and replacing it with a 60E?
If so you need the 4.8/5.3L flexplate.
Old Feb 10, 2009 | 08:12 PM
No this is in a 92 rcsb that i swapped a 6.0 in. the tranny is a 4l60 out of a 99 camaro. The flywheel on the 6.0 was originaly bolted up to a 4l80 but im using a 4l60.
Old Feb 10, 2009 | 08:52 PM
You need to swap to a 4.8L/5.3L flex plate and remove the spacer that should be in between the crank and flexplate.
If it happens to me a long crank 6.0L engine. 99 and back. You will not be able to use a 60e behind it.
This is a picture of a 5.3L flexplate on an 80E converter. The 80E bolt pattern is larger.
Old Feb 10, 2009 | 09:08 PM
Is there a spacer between the crank and flywheel and if so what is it there for.
Old Feb 10, 2009 | 09:26 PM
charcold-bowtie's Avatar
Its for a clearance difference of the 60e versus the 80e. I have a 4.8/5.3 flywheel if needed....
Old Feb 10, 2009 | 09:32 PM
You'll also need the shorter bolts flexplate to crank for the 5.3 flexplate.
Here is a pic of the spacer. It will probably come off attched to the flexplate.
Old Feb 10, 2009 | 09:33 PM
got those too. lol.
ferrellrooster
Mar 6, 2025 03:22 PM
Lamartian92
Sep 10, 2015 09:27 PM
dry_kill
11
Aug 28, 2015 09:53 PM
dantheman1540
Jul 29, 2015 04:45 PM
Denali man
Jul 19, 2015 03:52 PM
