Fly wheel problem
Alright so i went to put the torque converter bolts in and not to my suprise somthing else wasnt right. I see the bolt patern on my 6.0 flywheel is bigger than the 4l60 torque converter. The tranny is out of a 99 z28 so i geuss my question is what fly wheel do i need or can mine be modified to work.
You need to swap to a 4.8L/5.3L flex plate and remove the spacer that should be in between the crank and flexplate.
If it happens to me a long crank 6.0L engine. 99 and back. You will not be able to use a 60e behind it.
This is a picture of a 5.3L flexplate on an 80E converter. The 80E bolt pattern is larger.
Lamartian92
Sep 10, 2015 09:27 PM
dry_kill
11
Aug 28, 2015 09:53 PM
