flt lvl 5 4l65e ?'s
Old Feb 23, 2008 | 10:04 AM
jow02327's Avatar
Originally Posted by ZR1 DREAMING
What's up Jed? Has anybody else ridden in your truck when this happens? If so, how do they explain what's going on?
I also think, from what you've stated, you may have engaged limp mode... did you ever end up getting HPT?
no the bad part about it is that i am over an hour away from home and nobody that i know can help. i haven't got HPT yet, i have just been trying to get everything to get it ready for boost. what do i do to get it out of limp mode if that is whats wrong.
Old Feb 23, 2008 | 10:10 AM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Well without scanning its hard to say for sure but it sounds like it may be a stall code , PO757 the PCM become confused about the stall RPM verses output speed and assumes theres something wrong when theres not and sets limp mode. The fix if this is the case is to remove the test for that code from PCM programing.
Old Feb 23, 2008 | 10:24 AM
jow02327's Avatar
i do have predator tuner left from back in the day will it work to clear it
Old Feb 23, 2008 | 10:36 AM
silver-mod-o's Avatar
Hunt&Fisherator
where in tx are you??? unhook the batt for about 30 min or so and hook it up and try again and see what it does...
Old Feb 23, 2008 | 11:11 AM
Well it will work to clear the code not sure about deleting the test for the code, I know in EFILIVE theres just a box you uncheck and thats it but have never seen a predator. Yo might ask about that in the tuning section either here or on tech,
Old Feb 23, 2008 | 11:53 AM
FLT's Avatar
FLT
FormerVendor
ok i have an flt lvl 5 4l65e and a pi 3600 stall. i stalled it up and took off an it chirped all four tires and kinda jirked and then felt like i wasnt going any faster so i let off and came to a complete stop and put it in park i started going again and it didnt feel like it shifted i sped up to thirty-five mph at 2000rpm and put it down in third and nothing happened and then into second and it downshifted and then into first and it downshifted (i was slowing down with the brakes while doing this) checked the tcm fuse and it was fine ,.sorry for the novel and thanks in advance
Definitely sounds like a limp mode condition due to the 3600 PI. I would have to bet by what you have stated that the computer sent the trans to a limp mode condition when it shifted to second gear. 3RD gear starts. I will bet if you get it scanned you will have a PO751 or a PO757 code for the solenoids. You will need to have those codes cleared and then the test for the codes deleted with tuning. Vince
Old Feb 23, 2008 | 02:45 PM
jow02327's Avatar
ok the only error code i had was p0502 vehicle speed sensor circuit low input i cleared it and it shifts fine now is there a test for this code that has to be deleted.
Old Feb 23, 2008 | 03:24 PM
No you should not have to delete that one, I would check the pulg conection at the speed sensor though.
Old Feb 23, 2008 | 04:32 PM
Sambo53's Avatar
Something similar to this happend to my 1st level 5 4L70E. I was just cruising down the road doing about 70-75 and I just stepped on the gas to go around a slower driver (I didnt hammer it or anything) and mine started jerking real bad kinda like what your describing. The rpms were up quite a bit as well. So I took it to the dealership where I used to work at and my mechanic buddy drove it and said its trying to grab 3rd gear and theres nothing there to grab. Mine would also downshift into 2nd and 1st as well. I also noticed that my trans was running really hot as well. It usually runs 130-150 and it was up to 220 by the time I got to the dealership and its just a few miles down the road. I called chuck at finish line and told him what was going on. I ended up having to yank the trans the next day and send it back to them to fix. Chuck told me the stator shaft was out of alignment from the factory and thats what caused the problem. They fixed it free of charge and ate the shipping both ways for me. All I was out of was a few busted knuckles and some time taking the trans out and putting it back in. Needless to say I would give them a shout and they will take care of ya man.
SS94S10
Jan 3, 2019 01:57 PM
Wrecker 426
Oct 6, 2015 05:52 PM
trxmxzx
Sep 29, 2015 07:42 AM
chopperloco
Sep 28, 2015 08:40 AM
g6t6o
Sep 26, 2015 10:57 AM
