flt lvl 5 4l65e ?'s
no the bad part about it is that i am over an hour away from home and nobody that i know can help. i haven't got HPT yet, i have just been trying to get everything to get it ready for boost. what do i do to get it out of limp mode if that is whats wrong.
Well without scanning its hard to say for sure but it sounds like it may be a stall code , PO757 the PCM become confused about the stall RPM verses output speed and assumes theres something wrong when theres not and sets limp mode. The fix if this is the case is to remove the test for that code from PCM programing.
Well it will work to clear the code not sure about deleting the test for the code, I know in EFILIVE theres just a box you uncheck and thats it but have never seen a predator. Yo might ask about that in the tuning section either here or on tech,
ok i have an flt lvl 5 4l65e and a pi 3600 stall. i stalled it up and took off an it chirped all four tires and kinda jirked and then felt like i wasnt going any faster so i let off and came to a complete stop and put it in park i started going again and it didnt feel like it shifted i sped up to thirty-five mph at 2000rpm and put it down in third and nothing happened and then into second and it downshifted and then into first and it downshifted (i was slowing down with the brakes while doing this) checked the tcm fuse and it was fine ,.sorry for the novel and thanks in advance
No you should not have to delete that one, I would check the pulg conection at the speed sensor though.
Wrecker 426
Oct 6, 2015 05:52 PM
