everyone with belltech drop / lift struts please step in
Old Sep 23, 2012 | 06:02 PM
schino's Avatar
Default everyone with belltech drop / lift struts please step in
for the first time i watched my truck go down the road riding behind my brother. i knew it bounced some but once i saw it holy **** i needed new struts... so i ordered the belltech drop / lift struts. my setup is 2" drop spindles, 2" drop springs. so i figured i could set the struts at 0 and be good... (i was trying to decide to use stock springs and lower on struts or keep struts at 0 and keep lowering springs).. anyway i put the thing on the ground and its WAY lower then before! it sat on the fender liners. so i pull it all back apart and set the struts at +1" drop it on the ground and use my hand as a gauge and felt how it felt with stock struts. go around the block and now im sitting like a 1/4" from the fender liners. so what do i have to do put these things at 2 inch lift to put it where it was!?! also are you guys on 4" drop in front running the fender liners? i may just pull them out but i need to fix the camber problem from being lower and already out of adjustment
i never rubbed the liners before.. maybe these springs are shot and it has been just sitting on bump stops all this time??
Old Sep 24, 2012 | 07:49 PM
schino's Avatar
Damn all these views and no posts?? I had no choice but to use my truck today and I ended up melting holes through both liners. I may just throw the stock springs in and see where it lands me
Old Sep 25, 2012 | 02:42 PM
iamkeniff's Avatar
I cant help too much considering im on stock springs/struts, but mine doesnt bounce at all.
2" spindles, MCG coil relocators, 2" bushings, MCG flip kit, Shackle hanger kit.
Old Sep 25, 2012 | 03:37 PM
kashdriven's Avatar
Registered User
What size tires are you running?? You shouldn't have a problem rubbing on the liners til 5" of drop.
Old Sep 25, 2012 | 04:10 PM
slammedsilvy's Avatar
I thought I always read that the struts didn't have enough thread to use anything more than a 1" drop spring.
I would run stock springs if I were you, and set the struts at 2" drop. That's what I have had for well over 50,000+ miles and no issues.
Edit* By the way, I run 305/40/22 tires in the summer, and 265/65?/18 in the winter. I lost my passenger side inner fender years ago driving in deep snow, some snow became packed in between my tire and fender liner, I reversed over the lip in my driveway, and the force ripped my liner out. I removed the driver side liner when I installed my turbo. It gets a little dirty under hood, no other issues though.
Old Sep 25, 2012 | 10:07 PM
sand man's Avatar
had the same problem
2" lowring from the struts and 2" from the eibach coills and it robed with bumbs and I drove it for 4 days with 250 miles and didnt hurt the liners as much as you
runing 285/50/R20 tires
Old Sep 25, 2012 | 10:11 PM
iamkeniff's Avatar
275/55/20s on mine, no issues with my liners
Old Sep 26, 2012 | 06:57 AM
schino's Avatar
its prob at 5" of drop now. im going to put the stock springs back in and i guess try it first with struts set at 2" drop. i didnt have any problem putting the drop springs on them. i didnt have to compress the spring i could start the nut but by the time the nut was tightened the spring was under some tension. im running a 265/50/20 30.5" dia
im getting good at switching these things out btw. took about 40 minutes doing it in the driveway last time. maybe 30 this time haha
JordanH
Feb 28, 2017 07:22 PM
GXPJAY
Nov 5, 2015 06:49 AM
YenkoST
Aug 28, 2015 01:42 PM
silver-mod-o
18
Aug 25, 2015 08:18 AM
JordanH
Aug 8, 2015 03:08 PM
