escalade/SUV rear brake upgrade question
Old May 5, 2016 | 01:03 PM
GMCtrk's Avatar
Default escalade/SUV rear brake upgrade question
Looking at this all-inclusive powerstop kit for the rears. It uses a 30mm thick rotor instead of the 28mm thick one found on typical tahoes. Just want to confirm that this will directly bolt up to the stock truck backing plates with no clearance issues? Thanks
Old May 6, 2016 | 07:43 AM
Beatdown Z's Avatar
Laid Back
Sure will. I put the thicker rotors and matching calipers on my truck.
Old May 6, 2016 | 08:02 AM
DrX's Avatar
DrX
Kit says they are just reman/stock calipers. Must be some magic in those pads and the red powder coat.
"20 Percent More Stopping Power Than Other Brands"
Easy upgrade to dual piston though if just bolt up.
Old May 6, 2016 | 02:17 PM
GMCtrk's Avatar
Im putting stock brakes on because I can't pass inspection without ebrake. Got a nutjob inspector who followed everything to the book.
I'm sure the dual piston rears will be much stronger than these little OBS brakes.
The whole kit is $340. Reman loaded calipers are $115 each and then add in rotors and i wouldn't be saving much.
Old May 6, 2016 | 08:52 PM
silver-mod-o's Avatar
Hunt&Fisherator
Or keep paying $7 and find a different inspection place
Old May 6, 2016 | 11:11 PM
Wolftrk99's Avatar
The 28mm rotors are for tahoe the 30mm are from a suburban.... Oddly they use the same caliper and bracket.... Only thing you should have to do is either trim the backing plate up some or get some for a tahoe/butban withdual piston rears....
You have to have an parking brake to keep the truck from rolling downhill if the parking pawl fails or the truck comes out of park...
Old May 7, 2016 | 07:45 AM
Hunt&Fisherator
Only hill around Houston, Tx is an overpass or parking garage.
Old May 7, 2016 | 09:33 AM
Wolftrk99's Avatar
That was kinda my sarcastic point...lol
Old May 7, 2016 | 04:32 PM
GMCtrk's Avatar
ended up just buying the regular kit. stock calipers and flat rotors with oe ceramic pads. $100 cheaper. I have no need for the fancy rotors or red calipers.
jsleeper81
13
Jan 9, 2017 02:48 AM
About20ninj45
Apr 21, 2016 07:20 PM
hodge9386
Apr 20, 2016 06:48 AM
AWDTBSS
Apr 8, 2016 11:25 AM
