View Poll Results: Eaton or Powertrax ??
Eaton posi
88.89%
Powertrax locker
11.11%
Voters: 9. You may not vote on this poll
Old Feb 16, 2006 | 10:36 AM
Silent Thunder's Avatar
Default Eaton or Powertrax ??
I am building a 383 and will have some serious traction nightmares with my current one wheel wonder. I am looking at two different locker set ups, the Eaton or the Powertrax. Any suggestions or comments? Also I don't know how many splines my axles have, is there anyway to find out without having to tear it all apart? All I know is that I for sure have a 10 bolt with 3.42's. PLEASE VOTE
Old Feb 16, 2006 | 10:47 AM
TravisH's Avatar
I would go with the EATON. I had one in my last truck and I plan on putting one in this one. I was very happy with it.
Old Feb 16, 2006 | 10:56 AM
where did you buy yours at? I am looking at jegs.com and of course ebay
Old Feb 16, 2006 | 11:05 AM
hog's Avatar
hog
Avoid Powertrax lockrite or no slip, I have broken 3 Lock rites. I have had better lucjk with factory G80's over the Powertrax units.
I tried to save some money up front, but I should have gotten a Truetrac, Eaton or auburn off teh hop.
teh powertrax makes horrible noises and introduces much driveline slop. Sometime steh ABS will activate witout warning, bad setup IMO and in the opinion of others also.
peace
Hog
Old Feb 16, 2006 | 11:07 AM
virgils4.85spd's Avatar
Default Eaton
I know a guy whos puttin 725 hp to an eaton, broke axles 2 times and never damaged the posi unit!!!!!!!!! Ive got an eaton and i love it.
Derek
Old Feb 16, 2006 | 11:09 AM
thanks for the info hog. I can always count on you for useful info.
Old Feb 16, 2006 | 11:11 AM
where could I get a G80 at? And what do they come out of?
Old Feb 16, 2006 | 12:14 PM
Wilde Racing's Avatar
How do I change this text
G-80 came with most 2000+ body style 4x4's, most don't last that long, my G80 was the first thing I broke. I went to a eaton, and have had no problems with it.
Old Feb 16, 2006 | 03:00 PM
14 Second Truck Club
Eaton- all the way. I used to sell this stuff for a living and for street strip daily drivers they are the best unit. 19559-01 is what you will need. You will also need some special bearings(lm102949/lm102910) if this is for your 96 truck since the Eaton uses the better 99-up bearing surface diameter. Yours will also be 30 spline like the newer trucks and can actually use the same diff if you use the proper bearings.
The powertrax no-slips and Lock-rite's are good budget units because they are super easy to install since you dont need to remove or install the diff case or mess with the back lash, but they are actually weaker than a stock limited slip because most reuse the factory open case and add the stress of a locker to it.
Old Feb 16, 2006 | 04:00 PM
Dark Halo's Avatar
I have never had a noise problem or breaking problem with my powertrax no slip. The powertrax lockrite is junk but the no slip cost as much as an eaton posi just easier to install. I personally pefer the powertrax. I have had mine for over 2 years now and no problems
