Driveshaft Question
Old 01-06-2019, 07:36 PM
PFIX's Avatar
Default Driveshaft Question
Getting ready to upgrade the driveshaft on my 01 1500 ECSB Z71. Trucks making about 385 pound feet of torque and 400 horsepower at the tire. Should I change to larger U Joints with the new shaft? I’d rather not spend the extra dollars but I can and will if needed.
Old 01-06-2019, 08:44 PM
GoatChs's Avatar
I don't know what u-joints are in your truck, but I have oem Mechanics 3R series u-joints in my Yukon and at my current power levels I broke an Auburn Pro series LSD unit but u-joints are still holding up just fine.
Old 01-06-2019, 09:26 PM
PFIX's Avatar
Not sure of the cup size on the stock joint, if I upgrade I would go with a 1350 series joint. Cost jumps quite a bit buying a new slip yoke and pinion flange to fit the 1350 series joint. I’m thinking the stock joint size will be ok for my power level. I’m running 265/65/18 tires with 4:56 gears so I’m thinking the tires will break loose before I over stress the U joints.
Old 01-07-2019, 12:32 PM
terravast4's Avatar
1350 u joints and call it done
Old 01-12-2019, 12:00 PM
PFIX's Avatar
Got the new shaft in. 5” aluminum.125 wall thickness with 1350 spicer forged U Joints . That should be plenty strong and safe.
Old 01-14-2019, 01:35 PM
terravast4's Avatar
nice!!
Old 03-10-2019, 06:25 PM
slowness's Avatar
PFIX where did you get your drive shaft??
Old 03-11-2019, 12:13 PM
terravast4's Avatar
Is it a driveshaft specialist 5"?
jeff46614
06-03-2008 11:48 AM
TXsilverado
04-16-2008 12:39 AM
BOOSTAT4500
06-02-2007 02:03 PM
DuckOfDeath
08-30-2002 07:43 AM
Quick Reply: Driveshaft Question
