Front driveshaft question
Old Jun 2, 2007 | 11:51 AM
BOOSTAT4500's Avatar
Default Front driveshaft question
Will a front drive shaft from a 1/2 ton work with the T-case from a 3/4 ton? Or are they a different spline? The T-case is out of a 2001 2500 HD, behind a 4l80E
Old Jun 2, 2007 | 01:11 PM
blake2kz71's Avatar
No sir You will need different yokes if im not mistaken. Check out parish8's writeup and speed engineering--------------->
Old Jun 2, 2007 | 01:20 PM
Not a chance on that swap friend. You'll have a lot of **** to do to make that even feisable. Just out of curiosity, why do you want to do this anyway?
Old Jun 2, 2007 | 02:03 PM
I have a 71' Suburban that I installed a LQ4, 4l80E and T-case in. I don't have a front drive shaft and found a great deal on one out of an 06' half ton. I didn't know if the front output varied at all on the NP246 depending on what truck it's in.
1bad2k
Aug 18, 2015 09:50 PM
tgui
Aug 11, 2015 08:30 AM
USMCvet0311
Aug 1, 2015 07:45 AM
GM-only
Jul 19, 2015 10:48 PM
