Driveshaft Question
Driveshaft Question
Getting ready to upgrade the driveshaft on my 01 1500 ECSB Z71. Trucks making about 385 pound feet of torque and 400 horsepower at the tire. Should I change to larger U Joints with the new shaft? I’d rather not spend the extra dollars but I can and will if needed.
Not sure of the cup size on the stock joint, if I upgrade I would go with a 1350 series joint. Cost jumps quite a bit buying a new slip yoke and pinion flange to fit the 1350 series joint. I’m thinking the stock joint size will be ok for my power level. I’m running 265/65/18 tires with 4:56 gears so I’m thinking the tires will break loose before I over stress the U joints.
TXsilverado
04-16-2008 12:39 AM
