driveshaft problem
Old Mar 25, 2016 | 09:56 PM
Go5.3tt06's Avatar
Originally Posted by George C....
I just did the numbers and if read form right it was 63.375 for total length...that isnt there center to center
You spoke to them? Now they can do? I spoke to my local driveshaft stop they want try change to solid ujoint spicers and balance next week. Also I think I need try add spacer 1/2 or 1" insert trans mount to line up. I see tail yoke not line up it more lower on mine.
Old Mar 26, 2016 | 09:33 AM
silver-mod-o's Avatar
Hunt&Fisherator
Have you checked your operating angles???? Numerous threads here about what you need to see there.
Old Mar 26, 2016 | 09:40 AM
George C....'s Avatar
Formerly ScreamingL
Been in email contact with them to have one made by them
Old Mar 27, 2016 | 06:23 PM
Go5.3tt06's Avatar
Also other question. I should turn down from 4.11 to 3.73 because Im running turbo. Some people say not good idea to run 4.11 I need a help feedback. Than waste my money to change gear. I was wonder if you know how much worth GM OEM 3.73 gear would be cost?
Old Mar 27, 2016 | 07:07 PM
FFDP's Avatar
There is no harm in running 4.10's, it could just be a bigger factor if you were drag racing this car often. Different gear ratio's can help or hurt your times.
Old Mar 27, 2016 | 07:29 PM
Formerly ScreamingL
Max power
Max rpm
Tire size
Target mph
Punch these in and calculator will tell ya....my truck with 410s with current setup will trap mid 160s...my truck with 342s should be mid 180s
Old Mar 31, 2016 | 05:38 PM
Go5.3tt06's Avatar
update with yall, today I drop my shaft off. They have to cut off end to weld with 1350 to run solid joint on my reuse shaft or should I go heavy duty shaft whole new one from them. I need decide before I cant text them. They start work on mine tomorrow.
Old May 6, 2016 | 08:06 AM
tgui's Avatar
Any word on how this worked out?
Old Jun 30, 2016 | 10:31 PM
Go5.3tt06's Avatar
Sad still vibration 90 mph wheel let gas off. I got guy from ard Motorsport rode w me today he says my shaft bad. Am going buy whole new shaft maybe aluminum shaft and all solid u joint also. What you think.
Old Jul 1, 2016 | 08:21 AM
tgui's Avatar
Look into double cardan driveshafts. They don't have vibration issues and aren't too picky about angles. Pretty neat.
wolftrk99 told me about em
2500HDCobra
May 10, 2017 10:15 AM
misfitdsmer
Mar 17, 2016 06:30 AM
alex226
Feb 10, 2016 11:02 AM
DAYTONA81
Feb 8, 2016 04:41 PM
Infernohoe
Feb 1, 2016 02:51 AM
