Detroit Truetrac Set Up Problem???
Old Feb 8, 2015 | 05:07 PM
Dusty05's Avatar
Default Detroit Truetrac Set Up Problem???
When installing the Truetrac this weekend on my 03 I ran into an issue. I just swapped the G80 for the new Truetrac, swapped new bearings, torqued everything to spec and checked the backlash (between .003-.005). When the main caps are loose the backlash is within .003-.005 all the way around the ring gear. When the caps are torqued to spec there is a tight spot for about 40 degrees and the other 320 are free. The tight spot is noticeable by hand and the tolerance is tighter .002-.003.
I've thought it could be the ring gear not fully seated (maybe i missed a bur or flaw), or bad new bearings. Anyone have this issue happen before?
Old Feb 8, 2015 | 07:50 PM
Gadgetized's Avatar
It sounds like there could be debris under the ring gear. In order to check it properly it needs to have both caps tightened down.
You could remove the ring gear and install the truetrac. Put a dial indicator on the machined surface where the gear is mounted and turn it over to make sure it is true.
Old Feb 10, 2015 | 10:12 PM
Dusty05's Avatar
Update:
After taking it apart and double checking for debris under the ring gear it turns out that the Truetrac itself is out .002 after the caps have been tightened. Thanks for pointing us in that direction!
Old Feb 11, 2015 | 08:08 AM
tgui's Avatar
Originally Posted by Dusty05
Update:
I've been wanting a truetrac. Is this something you can fix? I'm still a truck noob and learning.
I'd love your input once you start driving it!
Old Feb 11, 2015 | 10:22 PM
Dusty05's Avatar
I'd say go for it. I've had three different truetrac's in different builds and this was the first time I've ran into a small issue. After setting it up again I feel a lot better about it!
Old Feb 12, 2015 | 08:20 AM
tgui's Avatar
Do you feel a 10 bolt with truetrac can handle quite a bit of HP/Torque?
Old Feb 12, 2015 | 08:01 PM
Fast_six oh's Avatar
Quick question im wanting a truetrac for my 9.5 14 bolt 6 lug axle...did the truetrac use the factory carrier bearings or were they aftermarket
Old Feb 12, 2015 | 08:36 PM
George C....'s Avatar
Formerly ScreamingL
i used Gm bearings on my trutrac in my two 14 bolts
Old Feb 12, 2015 | 08:59 PM
Jeebalow's Avatar
Yes, I believe there are members in the 10's with built 10 bolts. I think it was dirt track racer 81. Yep, here's a quote from him:
Originally Posted by dirt track racer 81
I run mid 10s in an ext cab and I'm launching out of the hole on 100% on the bottle no controllers or timing being pulled.
Just a truetrac and motive gears, stock axles.
That's from this thread:
https://www.performancetrucks.net/fo...handle-511791/
I put a truetrac into a 95 14 bolt and I just used the bearings that came in the install kit from Yukon. I'm 95% sure they're the same as the stock bearings, the kit is specific to your entire diff not just the carrier you put in it.
Old Feb 13, 2015 | 01:17 AM
Ok thanks fellas!!!
5.3Caprice
Nov 7, 2015 08:56 PM
Sexyrado327
Aug 2, 2015 04:08 PM
Dezert1500
Jul 30, 2015 02:51 PM
iregret
Jul 27, 2015 10:31 PM
Ketis
Jul 23, 2015 12:37 PM
