DETRIOT TRU TRAC, what else?
Old Oct 30, 2006 | 05:37 PM
Default DETRIOT TRU TRAC, what else?
I got my locker in the mail today, and ordering the LM603049 and LM 603012 bearings.
What gear fluid do I need?
I know I need a gasket also...
what else?
Old Oct 30, 2006 | 05:47 PM
unklej's Avatar
Jason at Randy's ring and pinion said to use dino 80/90 for the first 500 then you can go 80/90 syn. You will also need a shim kit to get teh carrier preload and back lash correct.
Jeff
Old Oct 30, 2006 | 05:59 PM
where can i get a shim kit
Old Oct 30, 2006 | 06:14 PM
KevinF56's Avatar
do you need a shim kit and stuff if you're just replacing the stock G80?
nick what'd you pay for the true trac? 400 or so? that's my next mod. since i got this 3000 stall in, i spin the tires too fast for the G80 to lock up properly.
Old Oct 30, 2006 | 06:21 PM
Rhino79's Avatar
9 Second Club
9 times out of 10 you will need an adjustable shim kit, the stock setup uses one thick one on each side. Measure the backlash before you remove anything, and use the shims accordingly to achieve the same backlash with the new carrier.
Old Oct 30, 2006 | 06:28 PM
but where do I get one, im puttin this in this week. the trutrac i believe is like 600 or so?
Old Oct 30, 2006 | 06:59 PM
Nick™'s Avatar
as for a gasket, silicone gasket maker in a tube works well, the stuff I used is made by "Permatex", available at any auto part store
Old Oct 30, 2006 | 08:59 PM
k thnx
Texas5.3_1251
Mar 5, 2016 08:10 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
97_ek
Sep 23, 2015 09:16 PM
94f150
Sep 13, 2015 06:39 PM
Trevor.j
Sep 10, 2015 03:16 PM
